Final tune, Need help |
Morph914 |
Mar 23 2022, 12:34 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Ok , so I have the engine running but it needs tuning. A little background, rebuilt stock 2.0 with D Jet, running a 123 dizzy. It fires right up and idles a little rough at first then smooths out. It revs fairly well and sounds good. The problem starts under load, it starts to stutter a bit.
I have not messed with the adjustment screw on the ECU or tried adjusting the throttle position sensor, or been able to check my fuel pressure. I’m hoping to rally any troops in the north Florida area to help me get these final details ironed out. Thanks in advance, John |
emerygt350 |
Mar 23 2022, 01:13 PM
Advanced Member Group: Members Posts: 2,146 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Looks gorgeous. None of those things besides fuel pressure will help you assuming the tps was installed correctly. Hopefully someone close can pop by. If you want to do the basics yourself, go to a flaps and rent a fuel pressure gauge, make sure it is 29lbs. Make sure the timing is good. Do you know what they set the 123 to? Is it Bluetooth or pot? That alone could be your problem. I see the advance port on the throttle body is plugged.
Van B |
Mar 23 2022, 01:27 PM
Senior Member Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Looks gorgeous. None of those things besides fuel pressure will help you assuming the tps was installed correctly. Hopefully someone close can pop by. If you want to do the basics yourself, go to a flaps and rent a fuel pressure gauge, make sure it is 29lbs. Make sure the timing is good. Do you know what they set the 123 to? Is it Bluetooth or pot? That alone could be your problem. I see the advance port on the throttle body is plugged. I'm not gonna lie. I stopped reading the thread and just gazed upon the beauty of that restored engine (IMG:style_emoticons/default/grouphug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:47 AM |
