Brian Fuerbach |
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California ![]() |
1974 1.8 with L- jet. Been playing with a wide band air fuel meter and noticed that when I lift the throttle the AFR goes to max value on the gauge. I thought it was supposed to go lean. I checked the throttle position switch and it checks out fine. Going to check the wiring harness next.
What else should I check? Decel valve? |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Ok so, two thoughts:
1.) set your decel valve to begin opening at 20 in-hg of vacuum. 2.) Does your 123 retain it’s advance on decel? I might be wrong here but I think the OEM dual vac pulls timing on decel |
Lo-Fi Version | Time is now: 3rd July 2025 - 12:10 PM |
