Brian Fuerbach |
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California ![]() |
1974 1.8 with L- jet. Been playing with a wide band air fuel meter and noticed that when I lift the throttle the AFR goes to max value on the gauge. I thought it was supposed to go lean. I checked the throttle position switch and it checks out fine. Going to check the wiring harness next.
What else should I check? Decel valve? |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Ok, I’m too tired to think straight but yes, your timing should retard when the throttle is closed regardless of RPM.
Timing retard vacuum is pulled from the bypass port on the throttle body, which is only used when the throttle plate is closed. Look at line B Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 3rd July 2025 - 01:11 PM |
