Brian Fuerbach |
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California ![]() |
1974 1.8 with L- jet. Been playing with a wide band air fuel meter and noticed that when I lift the throttle the AFR goes to max value on the gauge. I thought it was supposed to go lean. I checked the throttle position switch and it checks out fine. Going to check the wiring harness next.
What else should I check? Decel valve? |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Definitely possible.
As you've seen through my quests, the air from the decel valve is still measured air since it pulls from the intake boot after the AFM barn door. If the decel valve is flowing air when it shouldn't be, then the AFM will fuel the engine. I'm thinking maybe it could be too much fuel given the throttle body is fully closed in those moments. In my view, you only want the decel valve to open at moments of high vac... throttle chops etc. My point about timing is that if it remains advanced when the throttle is closed, then the burn won't be right and will almost certainly show a low AFR (rich) |
Lo-Fi Version | Time is now: 3rd July 2025 - 01:14 PM |
