Brian Fuerbach |
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California ![]() |
1974 1.8 with L- jet. Been playing with a wide band air fuel meter and noticed that when I lift the throttle the AFR goes to max value on the gauge. I thought it was supposed to go lean. I checked the throttle position switch and it checks out fine. Going to check the wiring harness next.
What else should I check? Decel valve? |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,980 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
So a decel hooked to the boot would be unmeasured air? AFM -> Boot -> throttle body? or is it Throttle body -> AFM -> Boot? If it is the first situation, the closed throttle body should reduce flow across the AFM and result in high plenum vacuum and the decel leading to the boot would cheat the AFM. I would think you would want the decel after the throttle body to be most effective and cheat the AFM.
Lo-Fi Version | Time is now: 3rd July 2025 - 12:34 PM |
