| MCShack |
Apr 4 2022, 05:12 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 7-March 21 From: Ohio, USA Member No.: 25,305 Region Association: Upper MidWest
Anyone see this story on Hagerty the other day? I found it slightly clever and somewhat humorous. Please delete if this has already been posted or is not appropriate for any reason. (IMG:style_emoticons/default/confused24.gif)
A few things to know before stealing my 914: https://www.hagerty.com/media/advice/a-few-...u-steal-my-914/ |
| rjames |
Apr 4 2022, 07:44 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif)
| ClayPerrine |
Apr 5 2022, 03:07 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 ![]() ![]() ![]() They even make them to replace the IDA3C. ![]() Clay |
| DRPHIL914 |
Apr 6 2022, 12:36 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 ![]() ![]() ![]() They even make them to replace the IDA3C. ![]() Clay @ClayPerrine ive not seen these before, but seems like they would work nice with right manifolds on a 2.1/2056 type IV motor, what EM system and ECU would you then use?, and linkage? a Tangerine carb linkage system? (IMG:style_emoticons/default/idea.gif) |
| ClayPerrine |
Apr 6 2022, 01:00 PM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 ![]() ![]() ![]() They even make them to replace the IDA3C. ![]() Clay @ClayPerrine ive not seen these before, but seems like they would work nice with right manifolds on a 2.1/2056 type IV motor, what EM system and ECU would you then use?, and linkage? a Tangerine carb linkage system? (IMG:style_emoticons/default/idea.gif) If it were me, I would use a Tangerine throttle linkage kit, and Microsquirt. If you already have carbs, you just need the throttle bodies. Clay |
MCShack A few things to know before stealing my 914 Apr 4 2022, 05:12 PM
Spoke That is pretty good. Apr 4 2022, 05:24 PM
r_towle All I kept thinking is that a valid response is a ... Apr 4 2022, 05:48 PM
ClayPerrine
All I kept thinking is that a valid response is a... Apr 4 2022, 06:43 PM
MCShack
[quote name='rjames' post='2993170' date='Apr 4 2... Apr 5 2022, 09:45 AM
rjames
Finally a legit reason to remove the FI and inst... Apr 5 2022, 10:00 AM
ClayPerrine
[quote name='ClayPerrine' post='2993227' date='Ap... Apr 5 2022, 10:42 AM
r_towle Dual carbs FTW Apr 5 2022, 05:47 PM
ClayPerrine
Dual carbs FTW
Luddite. :poke: Apr 6 2022, 11:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:19 PM |
