Identify base Boxster calipers from S calipers |
dwillouby |
Apr 23 2022, 03:36 PM
Member Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Hello
I got a set of front and rear Boxster calipers to upgrade onto my 914. Was told by the seller they are the non S versions. Having issues with finding the correct front pads. The pads for the base Boxster dont fit correctly. Spent a lot of time cleaning & refinishing these. Wondering if I actually received S calipers. Is there a way to confirm what calipers I have? Thanks David |
infraredcalvin |
Apr 23 2022, 04:04 PM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
start with posting photos and part numbers
are they already installed on car? pulled this info from a thread on the bird, in summary, S rotors are larger diameter and thicker. The S pad is larger. The caliper should be slightly wider to accommodate a 4mm thicker rotor. Non'S': F Disc 298mm, Pistons in Calipers 2x40,2x36 mm , pad area 216 cm^2 R Disc 292mm, Pistons in Calipers 2x30,2x28 mm , pad area 196 cm^2 "S": F Disc 319mm, Pistons in Calipers 2x40,2x36 mm, pad area 254 cm^2 R Disc 299mm, Pistons in Calipers 2x30,2x28 mm, pad area 196 cm^2 |
Lo-Fi Version | Time is now: 8th June 2024 - 07:25 PM |
