| Lockwodo |
Apr 29 2022, 06:38 PM
Member ![]() ![]() Group: Members Posts: 239 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
Hi all. As I work through the maintenance issues on the '74 2.0 I bought recently, I noticed that the cooling flaps are wide open (as they would be when engine is warmed up) all the time. Since this is the default position when a thermostat fails, I'll be checking the thermostat and wire/pulley mechanism. But just wondering what priority resolving this should have? It's not like I don't have plenty of other things to take care of (IMG:style_emoticons/default/smile.gif)
The car starts from cold, idles and runs well. I live in an area where it's unlikely I'll be starting and driving the car in temperatures below 60 degrees F. What do you think? |
emerygt350 Save it for last. Although hot oil will increase ... Apr 29 2022, 06:55 PM
wonkipop
Hi all. As I work through the maintenance issues... Apr 29 2022, 07:50 PM
Lockwodo
[quote name='Lockwodo' post='2998576' date='Apr 2... Apr 29 2022, 08:46 PM
wonkipop
[quote name='wonkipop' post='2998604' date='Apr 2... Apr 29 2022, 10:25 PM
wonkipop here is a link to the discussion.
the mexican one... Apr 29 2022, 10:40 PM
emerygt350 I pulled mine from an old bus motor a friend has l... Apr 30 2022, 05:32 AM
914Sixer Here you go. Brand new made in the USA. Guy also... Apr 30 2022, 05:54 AM
wonkipop
Here you go. Brand new made in the USA. Guy als... Apr 30 2022, 07:23 AM
emerygt350
Here you go. Brand new made in the USA. Guy al... Apr 30 2022, 08:31 AM
pbanders
Here you go. Brand new made in the USA. Guy als... Apr 30 2022, 03:46 PM
rhodyguy $129 a pop at Awesome Powder Coating for the ... Apr 30 2022, 07:15 AM
Lockwodo All great advice! Here's a related questi... Apr 30 2022, 09:07 AM
Superhawk996
All great advice! Here's a related quest... Apr 30 2022, 09:23 AM
bkrantz
All great advice! Here's a related quest... Apr 30 2022, 08:13 PM
Lockwodo
All great advice! Here's a related ques... Apr 30 2022, 09:53 PM
Superhawk996 With respect to the temperature gauge, here are th... Apr 30 2022, 09:31 AM
Lockwodo
With respect to the temperature gauge, here are t... May 23 2022, 08:19 PM
Superhawk996
[. . . does it look like the gauge needle is reg... May 24 2022, 06:29 AM
Lockwodo
[quote name='Lockwodo' post='3003765' date='May 2... May 24 2022, 06:52 AM
emerygt350 I am a believer in hot oil, but knowing what's... Apr 30 2022, 03:25 PM
Lockwodo I get that the engine temp needs to be maintained ... Apr 30 2022, 05:13 PM
emerygt350 Kind of. Idle in djet is a little complicated. Y... Apr 30 2022, 06:23 PM
rhodyguy When you remove the oil temp sensor the oil will p... May 1 2022, 11:27 AM
GregAmy If it helps for confidence in the gauge...I am run... May 24 2022, 06:56 AM
Lockwodo
If it helps for confidence in the gauge...I am ru... May 24 2022, 09:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 12:57 PM |
