Driving light questions ?, trying to sort non-running issue with Pilot lights. |
porschetub |
May 8 2022, 04:55 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring.
A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) |
porschetub |
May 8 2022, 10:04 PM
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring. A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) Thanks Mark I remember that article but couldn't find it as I came upon it when I bought the Pilot lights,bloody Haynes manual is no good (IMG:style_emoticons/default/mad.gif) . Rich yep thought that was the way,cheers. I have researched a bit more and think its an earth issue as I believe it is wrong ,if my relay is ok I reckon I should have control from the high beam as my car was imported to my country and would have to be complied that way. Cheers will report back. |
porschetub |
May 9 2022, 08:23 PM
Bought a set of these years ago got them mounted but never got them working after fixing old fog light wiring. A few questions ; Looking along left to right with the fuse board mounted which is the relay for these ? On a USA spec car what function of the light triggers the relay....I'am thinking low beam but not sure ? ,the compliance police in my country the rule used to be activation only on high beam from the light switch,and the driving lights need to be controlled via a switch which my car obviously has. Have done research and found some helpful info but still just trying to clear up a few things. TIA ,as really need to sort as I'am going to go nuts (IMG:style_emoticons/default/sad.gif) Thanks Mark I remember that article but couldn't find it as I came upon it when I bought the Pilot lights,bloody Haynes manual is no good (IMG:style_emoticons/default/mad.gif) . Rich yep thought that was the way,cheers. I have researched a bit more and think its an earth issue as I believe it is wrong ,if my relay is ok I reckon I should have control from the high beam as my car was imported to my country and would have to be complied that way. Cheers will report back. Found the wiring using that article Mark supplied,found relay buggered and swapped out from my extensive stock but it appears that I have no connection to trigger it so need to pull some dash switches and have a poke around which is a PITA (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) . |
Lo-Fi Version | Time is now: 7th June 2024 - 02:32 AM |
