> New 914 Owner
ogdougy
post May 10 2022, 01:30 PM
Hello all!
Just making a quick introduction. Made my first 914 purchase just about two weeks ago now and now starting to dive into this car.
Its a 73 non-California car with the EB 1.7. 100k ish miles on it with a motor that is leaking like crazy (more on that later). Single 32/36 weber. Classic Auto Air AC unit. Fiberglass GT Flares, Empi Replica Fuchs, and a bunch of shit ripped out of the engine bay. Bout all i know on these
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26536-1652211032.1.jpg)
Next to my AE86 Track car that is currently getting a cage welded in
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26536-1652211033.2.jpg)
So now getting to the real stuff. I have worked on boxers before, i have an 400 HP ej22 on e85 in my Forester (that needs to get pulled, RIP transmission). But I have never worked on an air cooled one.
Right now, i have been doing some basic maintenance that i do when i get a car. Change all fluids, been changing all the hoses on the motor because they look like the original ones, added a catch can, etc....
But of course after changing the oil and pressure washing the bottom on the engine/trans. I notice this thing is pissing oil out the rear main. So i decided with the unknown state of the motor, im just going to do a rebuild.
Reading around its seems like the easiest thing is to buy a AApistons 19XX cc or 20XX cc kit. I dont have a horsepower goal in mind. I just want this rebuild and hopefully get close to the same mpgs i had with the 1.7 (30 mpgs on the highway driving between Phoenix and Tucson)
The end goal with this motor. I have an entire pertronix flamethrower vacuum dist with the correct coil and plugs. While the 32/36 works for now. I will replace them with 40 IDF webers. Then some new headers and exhaust. The horsepower I get is what I get. Not too big of a concern.
Q1: With my motor being a 1.7 i have to get the heads machined to fit the larger cylinders and some massaging of the combustion chambers to get the the compression down. Correct?
Q2: Cam choice. Do people run the original 1.7 cam or just get a "street/oem" grind from Web.
This was a long one but I look forward to what i can learn!
930cabman
post May 10 2022, 01:59 PM
Welcome aboard
How is your new 914 currently running, with the exception of an oil leak or two? Could be a reasonably simple repair to get you along until your new engine is built. Will you be using your existing case? Good call with the Webers
ogdougy   New 914 Owner   May 10 2022, 01:30 PM
930cabman   Welcome aboard How is your new 914 currently runn...   May 10 2022, 01:59 PM
ogdougy   Welcome aboard How is your new 914 currently run...   May 10 2022, 07:47 PM
Dave_Darling   If you are not using the stock FI, ditch the cam a...   May 10 2022, 02:28 PM
Costa05   :wttc: Another Arizona 914 owner. Are you in Pho...   May 10 2022, 03:27 PM
808 WRX   Are you sure you don't want to swap in a subar...   May 10 2022, 04:06 PM
ogdougy   Well during the tear down it seems like a bunch of...   May 14 2022, 08:15 PM
bkrantz   Well during the tear down it seems like a bunch o...   May 14 2022, 08:32 PM
porschetub   Well during the tear down it seems like a bunch ...   May 14 2022, 11:16 PM
930cabman   Well during the tear down it seems like a bunch ...   May 16 2022, 04:56 AM
Justinp71   Well during the tear down it seems like a bunch o...   May 14 2022, 11:27 PM
Cairo94507   Welcome to the club. I would just add, if you are...   May 15 2022, 07:09 AM
aharder   :wttc: These are great cars to play with !...   May 15 2022, 09:35 AM
ogdougy   Well I at least found the culprit. Someone was as ...   May 15 2022, 09:33 PM
Shivers   Hey dude, helicoils have a use, It will get you...   May 15 2022, 09:48 PM
ogdougy   Hey dude, helicoils have a use, It will get you ...   May 18 2022, 09:44 AM
ogdougy   I got the motor out and have begun to take it apar...   May 21 2022, 08:16 PM
PanelBilly   I missed saying welcome.   May 21 2022, 09:00 PM
krazykonrad   :wttc: As you can already see, You've come to ...   May 22 2022, 01:58 PM
76-914   :wttc: That's the worst install of a helicoil ...   May 22 2022, 06:13 PM
ogdougy   Well motor is split and the bad stuff keeps on com...   May 26 2022, 03:56 PM
Shivers   The engine came out of a 914. Good news. It is bas...   May 26 2022, 04:25 PM
ClayPerrine   The engine came out of a 914. Good news. It is ba...   May 27 2022, 11:45 AM
Shivers   The engine came out of a 914. Good news. It is b...   May 27 2022, 12:43 PM
MM1   So. . .you’re in deep now . . .as many have said...   May 27 2022, 01:42 PM
ogdougy   As the updates come. I have bought a 2056 stroker ...   Jun 18 2022, 02:32 PM
ogdougy   So, as my parts are coming in I realized i have ma...   Jun 20 2022, 07:56 PM
jim-c   I highly recommend European Motorsports, Hawthorne...   Jun 21 2022, 08:52 AM
burton73   :wttc:   Sep 21 2023, 12:36 PM
krazykonrad   Also, ditch the single carb. If you are not runnin...   Jun 21 2022, 02:51 PM
Dave_Darling   Double-check the registers in the heads where the ...   Jun 22 2022, 10:32 PM
ogdougy   Engine is back together. Had the machine shop remo...   Feb 18 2023, 04:29 PM
rick 918-S   Nice work on that engine. :assimilate: You are a ...   Feb 18 2023, 08:38 PM
ogdougy   Nice work on that engine. :assimilate: You are a...   Feb 25 2023, 08:43 PM
ogdougy   Found the reason why my interior kept getting myst...   Feb 25 2023, 08:50 PM
ClayPerrine   Found the reason why my interior kept getting mys...   Feb 26 2023, 09:22 AM
Puebloswatcop   :wttc: And so the terminal illness begins....   Feb 26 2023, 07:35 AM
malcolm2   Welcome to the world.... and Hey, Register your VI...   Feb 26 2023, 08:30 AM
ogdougy   Final one all done. Just need to get some bondo to...   Mar 5 2023, 05:09 PM
Cairo94507   Before selecting a motor builder, I would vet them...   Mar 6 2023, 09:32 AM
ogdougy   Continuing the clean up. The battery tray is in an...   Mar 20 2023, 11:46 AM
ClayPerrine   Fuel lines are gone as well will be replacing it...   Mar 20 2023, 12:10 PM
ogdougy   Making some progress. Engine bay is as good as it ...   Apr 23 2023, 08:56 PM
ogdougy   Got the correct flywheel finally. Had a lot of per...   May 13 2023, 08:02 PM
Cairo94507   Very nice work; this is obviously not your first r...   May 14 2023, 06:35 AM
Geezer914   Very nice work! Welcome to the club.   May 14 2023, 10:37 AM
DRPHIL914   very nice and welcome - late welcome i just saw yo...   May 15 2023, 06:13 AM
ogdougy   very nice and welcome - late welcome i just saw y...   May 21 2023, 07:52 PM
Porschef   Putting new transmission side CV joints. All ne...   Sep 21 2023, 11:47 AM
r_towle   :wttc: Nice work!   May 21 2023, 09:15 PM
Shivers   Looks great! I added gussets to my brackets...   May 22 2023, 07:09 AM
ogdougy   Output shaft seals came in and in they went. New C...   May 30 2023, 12:27 AM
Cairo94507   Great work. It looks like the mufflers are oval. ...   May 30 2023, 07:44 AM
ogdougy   And we're back. Had one major set-back. My br...   Sep 20 2023, 05:45 PM
930cabman   An option may have been to chase the threads while...   Sep 21 2023, 03:55 PM
ogdougy   An option may have been to chase the threads whil...   Sep 23 2023, 06:44 PM
ogdougy   List of things to come from this weekend: 1. 2 of...   Sep 25 2023, 12:01 PM
Root_Werks   Great progress! Seems like you'll have th...   Sep 25 2023, 12:10 PM
Justinp71   Good job! People will think that has a motorc...   Sep 26 2023, 11:24 AM
Front yard mechanic   Sounds like z1   Sep 26 2023, 04:05 PM
ogdougy   Finally got it driving over the Christmas break. P...   Jan 13 2024, 09:17 PM
- Lo-Fi Version Time is now: 6th July 2025 - 02:10 PM
