| Mendivil26 |
May 10 2022, 02:25 PM
Newbie ![]() Group: Members Posts: 31 Joined: 26-July 18 From: Riverside, Ca. Member No.: 22,344 Region Association: Southern California |
Story time:
Last time I parked my '75 2.0 to restore the front suspension, it was running relatively fine. As usual, a simple task estimated to take a few weeks turned into months, due to lack of time & budget. A few months go by and I notice the interior is flooded in gas, thankfully the car had no carpets and nothing caught fire. I did my research and diagnosed the leak came from the plastic fuel lines that go through the tunnel; simple enough, I'll replace them with SS lines. I go ahead and clear the interior of any remaining fuel; drain the rest of the gas tank, only to notice the horrible condition it's in; chunks of rust coming out of it. Now I not only have to replace the fuel lines but I also have to either restore the tank or replace it (dansk tank $230 plus SS line $170). My goal with this car is to turn it into a baja inspired 914; and since I don't really care about "originality", I wondered: what if I replaced it with a universal fuel tank used by dune buggies/prerunners (Jaz, RCI, etc) and placed it in the rear trunk? They seem to be easy to find secondhand and not so expensive. I started looking into it and noticed obviously 914 racecars have "fuel cells" but they all kept them in the front. This is a list of pros & cons I came up with, and since it hasn't been done before I assume that it'll be a very unpopular inion, so please go ahead and talk me out of it since I'm biased and can only think of reasons to actually do it. Pros: No fuel lines running through tunnel = simpler system & shorter lines. Less or just as expensive for a unique or "custom" look, since I've never seen it done before. Shifts weight to the rear, which is better for my application Cons: Safety? Rear suspension is being reinforced so the tank could be protected by the cage I'll build around it in case of a rear end accident, but the fact that it's closer to the engine and hot temperatures might be a bigger issue. Anything else I might not be considering? Has someone seen it done before? If so, please share pictures/info. Picture of how it sits right now with UTV tires, for reference: Picture of what I'm thinking of maybe doing: ![]() |
| SirAndy |
May 11 2022, 11:18 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Picture of how it sits right now with UTV tires, for reference @Mendivil26 What size wheels and tires are you running on there? I've been thinking about going the Baja route since we're planning to retire down in the islands. (IMG:style_emoticons/default/idea.gif) |
| Dave_Darling |
May 12 2022, 06:31 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I've been thinking about going the Baja route since we're planning to retire down in the islands. You know what surrounds most islands people would retire to? Salt water. In Hawaii, pretty much everything made of any kind of metal corrodes into uselessness in a few years. Even "stainless" steel, aluminum, brass... Imagine the effect that salt spray would have on a 914. --DD |
| SirAndy |
May 12 2022, 09:57 PM
I've been thinking about going the Baja route since we're planning to retire down in the islands. You know what surrounds most islands people would retire to? Salt water. In Hawaii, pretty much everything made of any kind of metal corrodes into uselessness in a few years. Even "stainless" steel, aluminum, brass... Imagine the effect that salt spray would have on a 914. Sure, but once i move there i'll have another what, 15 years max that i'll be able to drive the car. That should be just about enough to have some fun. (IMG:style_emoticons/default/driving.gif) |
| Dave_Darling |
May 13 2022, 10:48 AM
Sure, but once i move there i'll have another what, 15 years max that i'll be able to drive the car. 15 years of driving is very optimistic, unless you live well up-hill away from the ocean. I feel like a 914 or other old European car would last about 5 years. Maybe 10 if you're careful and never take the car near the water. --DD |
Mendivil26 Fuel tank relocation to rear? May 10 2022, 02:25 PM
ClayPerrine That is an absolutely terrible idea. The rear tru... May 10 2022, 03:08 PM
ValcoOscar
That is an absolutely terrible idea. The rear tr... May 10 2022, 03:11 PM
ClayPerrine
That is an absolutely terrible idea. The rear t... May 11 2022, 10:28 AM
Van B
That is an absolutely terrible idea. The rear tr... May 11 2022, 10:46 AM
emerygt350 That trunk gets super warm. I would do the front ... May 10 2022, 03:21 PM
930cabman Think Ford Pinto, rear end collision
BTW: she loo... May 10 2022, 03:26 PM
Craigers17 I would leave in up front as well, but since you a... May 10 2022, 04:14 PM
rhodyguy With the fuel storage in the stock location, less ... May 10 2022, 04:43 PM
BillJ Sticking it in the rear is bad. May 10 2022, 04:49 PM
Krieger
:agree: :rot... May 12 2022, 10:55 PM
Front yard mechanic open up the hood and put a aluminum cylinder tank ... May 10 2022, 05:02 PM
jrmdir
open up the hood and put a aluminum cylinder tank... May 20 2022, 01:49 PM
Front yard mechanic
[quote name='Front yard mechanic' post='3000947' ... Jun 3 2022, 02:09 PM
PCH Also, if you put the tank in the back, you won... May 10 2022, 05:55 PM
Bullethead Baja 914's are cool, but proper weight distrib... May 10 2022, 06:12 PM
Lockwodo Clay, I have to wonder about the bag of kitty litt... May 11 2022, 10:36 AM
ClayPerrine
Clay, I have to wonder about the bag of kitty lit... May 11 2022, 11:08 AM
Spoke Compared to Clay's crash, mine was a minor den... May 11 2022, 11:05 AM
Shivers I understand wanting to keep the front end light f... May 11 2022, 11:39 AM
Mendivil26 Thank you all for the great responses!
I under... May 12 2022, 10:59 AM
sixnotfour :beer2: May 12 2022, 11:22 PM
mlindner Not what your looking for but just a different loo... May 13 2022, 04:00 AM
Mendivil26
Not what your looking for but just a different lo... May 20 2022, 09:32 AM
Not what your looking for but just a different l... May 20 2022, 09:36 AM
SirAndy Reproduction 356 fuel tank. $400-500.
It doe... May 20 2022, 09:55 AM
930cabman
It do... May 20 2022, 01:06 PM
mlindner Yes it is a 356 tank, it was going to be a fuel ce... May 20 2022, 11:45 AM
mlindner SirAndy I do understand where you are coming from,... May 20 2022, 02:08 PM
Mendivil26 Thanks to everyone for your great advise.
I found ... Jun 3 2022, 12:33 PM
914 Ranch I'm sorry I can't give you a link, but the... Jun 3 2022, 05:07 PM
bkrantz Not to rain on any parades, but the frunk also ser... Jun 3 2022, 08:29 PM
Mikey914 Factory put the tank where they did for a reason. ... Jun 4 2022, 02:30 AM
mlindner I get the crumple zones BUT all the early 911 had ... Jun 4 2022, 06:52 AM
bkrantz
I get the crumple zones BUT all the early 911 had... Jun 4 2022, 11:25 AM
Dave_Darling If you'll look carefully, you might notice tha... Jun 5 2022, 03:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:22 AM |
