| jim_hoyland |
May 16 2022, 02:12 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,129 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Got a pair of new latches for the targa top. Seven horizontal screws and 5 vertical from underneath. Screw heads are buried into the pad. Any tricks here ?I found maybe three of the screws.
Attached thumbnail(s) Attached image(s)
Root_Werks On the pad I removed (and tossed), the foam inside... May 16 2022, 02:34 PM
jim_hoyland
On the pad I removed (and tossed), the foam insid... May 16 2022, 03:06 PM
JamesM
The screw heads don't always match straight t... May 18 2022, 01:23 PM
Root_Werks I would take the two side panels off, makes things... May 16 2022, 03:50 PM
jim_hoyland
I would take the two side panels off, makes thing... May 16 2022, 03:53 PM
windforfun The AA roll bar pad fits almost perfectly. And ho... May 16 2022, 06:57 PM
jim_hoyland
The AA roll bar pad fits almost perfectly. And h... May 16 2022, 07:39 PM
Front yard mechanic Use a long number one screwdriver . The length hel... May 16 2022, 07:13 PM
76-914 Jim, the correct size Phillips is #1 on the list. ... May 16 2022, 07:17 PM
jim_hoyland Got the #1 long shaft screwdriver. Had to stop aft... May 16 2022, 07:41 PM
windforfun
Got the #1 long shaft screwdriver. Had to stop af... May 16 2022, 07:53 PM
windforfun BTW, some of the screws may already be missing. M... May 17 2022, 04:11 PM
jim_hoyland This project is on hold for awhile. Will restart w... May 17 2022, 06:00 PM
bob164 Jim,
When you get back to it, give me a call and I... May 18 2022, 06:33 PM
jim_hoyland
Jim,
When you get back to it, give me a call and ... May 18 2022, 06:51 PM
Dave_Darling I think I recall that the two little tiny screws i... May 18 2022, 11:16 PM
windforfun
I think I recall that the two little tiny screws ... May 19 2022, 10:12 AM
mepstein I hate those tiny screws. Made worse after 50 year... May 19 2022, 08:38 AM
jim_hoyland Restarting the targa pad removal. Gonna pull the p... Aug 16 2022, 04:18 PM
JeffBowlsby I use an awl as a probe to locate the screw heads. Aug 16 2022, 04:50 PM
jim_hoyland
I use an awl as a probe to locate the screw heads... Aug 16 2022, 07:05 PM
914_teener I'll be in Long Beach this coming Sat Jim if y... Aug 16 2022, 07:25 PM
jim_hoyland
I'll be in Long Beach this coming Sat Jim if ... Aug 16 2022, 08:52 PM
jim_hoyland After hours of frustration, I trekked down to Keit... Aug 18 2022, 04:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 09:07 PM |
