| jim_hoyland |
May 16 2022, 02:12 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,129 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Got a pair of new latches for the targa top. Seven horizontal screws and 5 vertical from underneath. Screw heads are buried into the pad. Any tricks here ?I found maybe three of the screws.
Attached thumbnail(s) Attached image(s)
| Root_Werks |
May 16 2022, 02:34 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,053 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
On the pad I removed (and tossed), the foam inside the little holes had been shredded up enough to block the screw heads. I used a little pick to sort of clean out each hole. The screw heads don't always match straight to the hole in the pad either. It's frustrating and slow. You should be able to see each screw head....should.
jim_hoyland Targa pad removal… May 16 2022, 02:12 PM
jim_hoyland
On the pad I removed (and tossed), the foam insid... May 16 2022, 03:06 PM
JamesM
The screw heads don't always match straight t... May 18 2022, 01:23 PM
Root_Werks I would take the two side panels off, makes things... May 16 2022, 03:50 PM
jim_hoyland
I would take the two side panels off, makes thing... May 16 2022, 03:53 PM
windforfun The AA roll bar pad fits almost perfectly. And ho... May 16 2022, 06:57 PM
jim_hoyland
The AA roll bar pad fits almost perfectly. And h... May 16 2022, 07:39 PM
Front yard mechanic Use a long number one screwdriver . The length hel... May 16 2022, 07:13 PM
76-914 Jim, the correct size Phillips is #1 on the list. ... May 16 2022, 07:17 PM
jim_hoyland Got the #1 long shaft screwdriver. Had to stop aft... May 16 2022, 07:41 PM
windforfun
Got the #1 long shaft screwdriver. Had to stop af... May 16 2022, 07:53 PM
windforfun BTW, some of the screws may already be missing. M... May 17 2022, 04:11 PM
jim_hoyland This project is on hold for awhile. Will restart w... May 17 2022, 06:00 PM
bob164 Jim,
When you get back to it, give me a call and I... May 18 2022, 06:33 PM
jim_hoyland
Jim,
When you get back to it, give me a call and ... May 18 2022, 06:51 PM
Dave_Darling I think I recall that the two little tiny screws i... May 18 2022, 11:16 PM
windforfun
I think I recall that the two little tiny screws ... May 19 2022, 10:12 AM
mepstein I hate those tiny screws. Made worse after 50 year... May 19 2022, 08:38 AM
jim_hoyland Restarting the targa pad removal. Gonna pull the p... Aug 16 2022, 04:18 PM
JeffBowlsby I use an awl as a probe to locate the screw heads. Aug 16 2022, 04:50 PM
jim_hoyland
I use an awl as a probe to locate the screw heads... Aug 16 2022, 07:05 PM
914_teener I'll be in Long Beach this coming Sat Jim if y... Aug 16 2022, 07:25 PM
jim_hoyland
I'll be in Long Beach this coming Sat Jim if ... Aug 16 2022, 08:52 PM
jim_hoyland After hours of frustration, I trekked down to Keit... Aug 18 2022, 04:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 09:07 PM |
