> Oil gallery leak under cylinders 3 & 4, Wiggle room with push rod tubes loosened?
mgphoto
post May 17 2022, 07:48 PM
"If there is a mistake it will find me"
Hello,
I am trying to repair a leak in the oil gallery under cylinders 3-4
As you can nearly see, the air deflection plate is up against the leaking clean out plug.
I would like to know from someone who has done this before, can I remove the rocker arms and pull the push rods and tubes as far as they will go, can I move the deflector enough to get access to the plug?
Thanks for your help.
Mike
r_towle
post May 18 2022, 09:34 PM
Custom Member
I would pull it, mount on engine stand, flip it over and go from there.
You might need to pull the head and cylinders to get where you need to with the proper tools.
- Lo-Fi Version Time is now: 30th April 2026 - 09:26 PM
