Another trailing arm bushing question, 914rubber ones fine on stock pin? |
nditiz1 |
May 19 2022, 06:31 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I noticed while removing my left rear shock that my trailing arm likes to move around a lot. That explains the clunk I heard on my test drive.
I was going to purchase the 914rubber kit, but looks like they are oos on the SS pins. Can I just use the rubber bushings with my current pin barring it has not gotten worn out from current bushing failure? OR if I'm going that route should I get the RD ones, just the bushings. I looked at the elephant kit, but I hate paying for extra tools I don't need. Lastly, Move brake caliper and lines off arm. Unbolt drive shaft from trans flange. Remove rotor Unbolt shock. Remove trailing arm bracket and pin. That's it to get it out right? |
TonyH |
May 19 2022, 07:32 AM
Member Group: Members Posts: 50 Joined: 30-January 22 From: Normandy, France Member No.: 26,296 Region Association: France |
I am just about to do mine, so I will let you know!
TonyH |
Lo-Fi Version | Time is now: 11th June 2024 - 09:14 PM |
