Dim slow turn signal |
jmargush |
May 19 2022, 04:58 AM
Member Group: Members Posts: 461 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
My right side turn signal is not as bright as the left side.
When the headlights are on it flashes slower than the left side. Is this likely a ground issue, or could something else be the culprit? |
nditiz1 |
May 19 2022, 08:29 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
^ this is probably the issue.
I experienced the same thing with mine. I ended up swapping buckets and that corrected the issue. Too much corrosion that I couldn't seem to clean to get a good connection. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:56 PM |
