Mallory distributor orientation |
Geezer914 |
May 20 2022, 11:53 AM
Geezer914 Group: Members Posts: 1,433 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1?
cgnj |
May 20 2022, 07:52 PM
Senior Member Group: Members Posts: 624 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1? I reindexed the drive gear. I have one with vacuum advance and that was the only way it would fit. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:49 PM |
