Dynamat |
Dynamat |
Medtner3 |
May 20 2022, 06:30 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
Dynamat: What thickness should you use? should you put over the tar on the floor should you throw away the rubber pad behind the backpad on the firewall?
I need some adivce: I want to add sound barrier under my backpad and possibly floor. I currently have the black tar floor, nothing in doors and rubber pad behind backpad which honestly has seen better days and looks pretty nasty. Should I add any sound proofing to the floor before I carpet? If so, what thickness? Also, should I throw out the old cracked and dirty rubber pad and put sound proofing on top of the firewall behind the backpad or leave it as is? Thanks in advance for advice |
dr914@autoatlanta.com |
May 23 2022, 03:07 PM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the 914s are quite quiet when in stock dress so by restoring the original sound deadening to the floor, the back wall and the engine compartment and making sure that the rear window is well sealed you will be all set. Don't waste time on snake oil solutions like lizard what ever or what ever
Dynamat: What thickness should you use? should you put over the tar on the floor should you throw away the rubber pad behind the backpad on the firewall? I need some adivce: I want to add sound barrier under my backpad and possibly floor. I currently have the black tar floor, nothing in doors and rubber pad behind backpad which honestly has seen better days and looks pretty nasty. Should I add any sound proofing to the floor before I carpet? If so, what thickness? Also, should I throw out the old cracked and dirty rubber pad and put sound proofing on top of the firewall behind the backpad or leave it as is? Thanks in advance for advice |
Lo-Fi Version | Time is now: 22nd May 2024 - 09:21 PM |
