Chaznaster |
Member ![]() ![]() Group: Members Posts: 325 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States ![]() ![]() |
Hello all. With the weather getting warmer, I have started thinking about getting a handle on my engine temperature. I looked at quite a few discussions on here and most were about interpreting/ calibrating the stock(ish) gauges.
I have no sender at the taco plate and no gauge. I happened on the approach to measure with a dipstick thermometer but it appears those are all NLA. I have a 123 dizzy that transmits temperature but am pretty sure the base of that is far away from the sump and probably not an accurate reading. A few questions: * Is the 123 temperature value good for anything? Maybe there is a conversion? Although I expect it will warm slower and cool faster than the sump in the best case. * What is the most straightforward way (I am OK with some spend and even running wires to the dash) to get a reliable reading? Gauge (VDO or other), thermal camera pointed at the oil pan? Other? I appreciate your guidance ... |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Oil temperature is not engine temperature. It is just oil temperature, and impacted by variables that only impact the oil.
The 123 gives a good indication of crankcase temperature, which is adequate in a water-cooled engine, but not very indicative of anything with our engines, where cylinder head temperatures make or break the engine. My article on engine temperatures is still somewhere here on 914 World, it gives some good information. |
SavingManuals |
Member ![]() ![]() Group: Members Posts: 100 Joined: 5-January 21 From: Metro Detroit Member No.: 25,044 Region Association: None ![]() ![]() |
Oil temperature is not engine temperature. It is just oil temperature, and impacted by variables that only impact the oil. The 123 gives a good indication of crankcase temperature, which is adequate in a water-cooled engine, but not very indicative of anything with our engines, where cylinder head temperatures make or break the engine. My article on engine temperatures is still somewhere here on 914 World, it gives some good information. Found this: "914 Info" page -> Technical Articles -> » Type IV Cylinder Head Temperatures - by Jake Raby |
Lockwodo |
Member ![]() ![]() Group: Members Posts: 213 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
Oil temperature is not engine temperature. It is just oil temperature, and impacted by variables that only impact the oil. The 123 gives a good indication of crankcase temperature, which is adequate in a water-cooled engine, but not very indicative of anything with our engines, where cylinder head temperatures make or break the engine. My article on engine temperatures is still somewhere here on 914 World, it gives some good information. Found this: "914 Info" page -> Technical Articles -> » Type IV Cylinder Head Temperatures - by Jake Raby Very good! I just ordered the gauge and spark plug thermocouple. |
Lockwodo |
Oil temperature is not engine temperature. It is just oil temperature, and impacted by variables that only impact the oil. The 123 gives a good indication of crankcase temperature, which is adequate in a water-cooled engine, but not very indicative of anything with our engines, where cylinder head temperatures make or break the engine. My article on engine temperatures is still somewhere here on 914 World, it gives some good information. Found this: "914 Info" page -> Technical Articles -> » Type IV Cylinder Head Temperatures - by Jake Raby Very good! I just ordered the gauge and spark plug thermocouple. Could someone comment on the best routing for the wire from the thermocouple under plug #3 to the gauge installed on the dash? Preferably a graphic of some sort or description would be great. Thanks |
Lo-Fi Version | Time is now: 9th May 2025 - 12:32 PM |
