> Measuring engine temperature, No taco sender or gauge ...
Chaznaster
post May 24 2022, 05:45 PM
Hello all. With the weather getting warmer, I have started thinking about getting a handle on my engine temperature. I looked at quite a few discussions on here and most were about interpreting/ calibrating the stock(ish) gauges.
I have no sender at the taco plate and no gauge.
I happened on the approach to measure with a dipstick thermometer but it appears those are all NLA.
I have a 123 dizzy that transmits temperature but am pretty sure the base of that is far away from the sump and probably not an accurate reading.
A few questions:
* Is the 123 temperature value good for anything? Maybe there is a conversion? Although I expect it will warm slower and cool faster than the sump in the best case.
* What is the most straightforward way (I am OK with some spend and even running wires to the dash) to get a reliable reading? Gauge (VDO or other), thermal camera pointed at the oil pan? Other?
I appreciate your guidance ...
930cabman
post May 26 2022, 08:12 AM
Is anyone using the tapped hole the factory used for the CHT sender? Seems like an easy location to grab the head temp
Chaznaster   Measuring engine temperature   May 24 2022, 05:45 PM
Bullethead   After building a fresh motor for my T34 VW, I used...   May 24 2022, 06:17 PM
mgphoto   The 123 is pretty close, oil temp gauge is very sl...   May 24 2022, 06:31 PM
VaccaRabite   I would (and do) use a head temp sensor on the #3 ...   May 25 2022, 05:57 AM
barefoot   I'm using very inexpensive TC under the #3 spa...   May 25 2022, 06:19 AM
Jake Raby   Oil temperature is not engine temperature. It is j...   May 25 2022, 07:33 AM
SavingManuals   Oil temperature is not engine temperature. It is ...   May 25 2022, 10:16 AM
Lockwodo   Oil temperature is not engine temperature. It is...   May 25 2022, 11:09 AM
Lockwodo   [quote name='SavingManuals' post='3004037' date='...   May 25 2022, 05:30 PM
emerygt350   I had a hard time finding the info link, so here i...   May 25 2022, 12:55 PM
Jake Raby   I had a hard time finding the info link, so here ...   May 25 2022, 01:50 PM
michael7810   Sorry no pics but I was able to run dual CHTs and ...   May 25 2022, 06:51 PM
Lockwodo   Sorry no pics but I was able to run dual CHTs and...   May 25 2022, 09:16 PM
FlacaProductions   Same there - went through the speedo hole.   May 25 2022, 06:59 PM
Chaznaster   Wow. Great input - thanks so much to all! @Ja...   May 25 2022, 07:19 PM
VaccaRabite   My thermocouple wire goes to the head via the stoc...   May 26 2022, 07:09 AM
Lockwodo   My thermocouple wire goes to the head via the sto...   May 26 2022, 08:08 AM
930cabman   Is anyone using the tapped hole the factory used f...   May 26 2022, 08:12 AM
GregAmy   Hmm - so the thermocouple ring has a shank where ...   May 26 2022, 08:54 AM
barefoot   [quote name='Lockwodo' post='3004265...   May 26 2022, 11:09 AM
Jake Raby   This is the worst place to gather CHT data. I ha...   May 26 2022, 09:17 AM
930cabman   This is the worst place to gather CHT data. I h...   May 26 2022, 11:28 AM
- Lo-Fi Version Time is now: 7th July 2025 - 05:31 AM
