ogdougy |
Newbie ![]() Group: Members Posts: 49 Joined: 9-May 22 From: Arizona Member No.: 26,536 Region Association: Southwest Region ![]() |
Hello all!
Just making a quick introduction. Made my first 914 purchase just about two weeks ago now and now starting to dive into this car. Its a 73 non-California car with the EB 1.7. 100k ish miles on it with a motor that is leaking like crazy (more on that later). Single 32/36 weber. Classic Auto Air AC unit. Fiberglass GT Flares, Empi Replica Fuchs, and a bunch of shit ripped out of the engine bay. Bout all i know on these (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26536-1652211032.1.jpg) Next to my AE86 Track car that is currently getting a cage welded in (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26536-1652211033.2.jpg) So now getting to the real stuff. I have worked on boxers before, i have an 400 HP ej22 on e85 in my Forester (that needs to get pulled, RIP transmission). But I have never worked on an air cooled one. Right now, i have been doing some basic maintenance that i do when i get a car. Change all fluids, been changing all the hoses on the motor because they look like the original ones, added a catch can, etc.... But of course after changing the oil and pressure washing the bottom on the engine/trans. I notice this thing is pissing oil out the rear main. So i decided with the unknown state of the motor, im just going to do a rebuild. Reading around its seems like the easiest thing is to buy a AApistons 19XX cc or 20XX cc kit. I dont have a horsepower goal in mind. I just want this rebuild and hopefully get close to the same mpgs i had with the 1.7 (30 mpgs on the highway driving between Phoenix and Tucson) The end goal with this motor. I have an entire pertronix flamethrower vacuum dist with the correct coil and plugs. While the 32/36 works for now. I will replace them with 40 IDF webers. Then some new headers and exhaust. The horsepower I get is what I get. Not too big of a concern. Q1: With my motor being a 1.7 i have to get the heads machined to fit the larger cylinders and some massaging of the combustion chambers to get the the compression down. Correct? Q2: Cam choice. Do people run the original 1.7 cam or just get a "street/oem" grind from Web. This was a long one but I look forward to what i can learn! |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,074 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
The engine came out of a 914. Good news. It is basically in one piece. Good news. You split the case and now have access to install new parts. Good news. You're about to find out what parts cost. Bad news. But I got for my 1.7 a 2.0 counter balanced crank, rods, 2.0 P&C's, lightened flywheel and a nice carbureted cam shaft. A little head work and a set of modified 40 idf's and it became a whole new car. Then it was time for brakes, suspension and God I've got to do something about this shifter! And then... (IMG:style_emoticons/default/smile.gif) @ogdougy
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,422 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The engine came out of a 914. Good news. It is basically in one piece. Good news. You split the case and now have access to install new parts. Good news. You're about to find out what parts cost. Bad news. But I got for my 1.7 a 2.0 counter balanced crank, rods, 2.0 P&C's, lightened flywheel and a nice carbureted cam shaft. A little head work and a set of modified 40 idf's and it became a whole new car. Then it was time for brakes, suspension and God I've got to do something about this shifter! And then... (IMG:style_emoticons/default/smile.gif) @ogdougy That is called "Dirk Wright's Disease"...... and you have it bad. |
Shivers |
The engine came out of a 914. Good news. It is basically in one piece. Good news. You split the case and now have access to install new parts. Good news. You're about to find out what parts cost. Bad news. But I got for my 1.7 a 2.0 counter balanced crank, rods, 2.0 P&C's, lightened flywheel and a nice carbureted cam shaft. A little head work and a set of modified 40 idf's and it became a whole new car. Then it was time for brakes, suspension and God I've got to do something about this shifter! And then... (IMG:style_emoticons/default/smile.gif) @ogdougy That is called "Dirk Wright's Disease"...... and you have it bad. Hahaha, got that right. Found AA in Hot VW in 82-83(?), and it has been chronic ever since. To my Wife's chagrin, I had a really bad bout in the early 90's. (IMG:style_emoticons/default/biggrin.gif) Just now putting some parts on I bought back then. ogdougy, don't let this deter you, "Dirk Wright's Disease" is contagious but can be avoided. That said, when you find a way to avoid it, let me know. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 6th July 2025 - 01:37 PM |
