> Honk Honk!.... " yea, I know I am stalled out and blocking the intersection @$$H*L$"
shredtherad
post May 27 2022, 05:08 PM
Hello, hello! The new to me 914 is so rad! Love it... went out for a bit of cruise and about 20+ mins into the drive, while approaching a trafific light ( red ) the car came down to idle and that kept going and poof... stall. It did not start, I blocked the lane and angry SUV's and Tesla's honked at me. I did however get it going again after putting the pedal to the floor while starting and it fired up and drove fine, until... idle at the stop sign. Poof, stall. BUT this time pedal to the floor and fired right up.
Thoughts, where should I begin. I have attached a video of the issue... thanks! Beep Beep.
https://www.youtube.com/watch?v=Mx47LENYFuU
Superhawk996
post May 27 2022, 05:44 PM
Watched your video. By video title it says stock so I'm going to roll with fuel injected.
Problem is I think you're looking for an easy agreed upon solution to your problem. You're going to get plenty of opinions or "his fixed my car" responses which might help or might have zero applicability to your problem and will keep you running in circles.
If you're new to 914's, and 50 year old fuel injection, you should probably start familiarizing yourself with the Brad Anders pages and the overview of D-jet fuel injection components and how to troubleshoot them.
https://members.rennlist.com/pbanders/DJetP...tm#troubleshoot
shredtherad
post May 27 2022, 08:48 PM
QUOTE(Superhawk996 @ May 27 2022, 05:44 PM) *
Yup, 73 1.7 with FI.
Of course I am looking for the easy fix (IMG:style_emoticons/default/smile.gif) but know that is not what is going to happen, I do however need to start somewhere. Thanks for the link! I will be reading that one!
r_towle
post May 28 2022, 08:52 AM
Custom Member
QUOTE(shredtherad @ May 27 2022, 10:48 PM) *
An easy fix is to plan your trips to be less than 20 minutes
shredtherad
post May 28 2022, 08:57 AM
QUOTE(r_towle @ May 28 2022, 08:52 AM) *
haha... basically what I have been doing (IMG:style_emoticons/default/smile.gif)
shredtherad   Honk Honk!.... " yea, I know I am stalled out and blocking the intersection @$$H*L$"   May 27 2022, 05:08 PM
Big Len   I think the first general question would be carbs ...   May 27 2022, 05:22 PM
shredtherad   I think the first general question would be carbs...   May 27 2022, 08:45 PM
emerygt350   So sorry! What is the year and fuel system? C...   May 27 2022, 05:23 PM
shredtherad   So sorry! What is the year and fuel system? ...   May 27 2022, 08:45 PM
Superhawk996   Watched your video. By video title it says stock ...   May 27 2022, 05:44 PM
shredtherad   Watched your video. By video title it says stock...   May 27 2022, 08:48 PM
r_towle   [quote name='Superhawk996' post='3004559' date='M...   May 28 2022, 08:52 AM
shredtherad   [quote name='Superhawk996' post='3004559' date='...   May 28 2022, 08:57 AM
76-914   So it takes about 20 min's before this happens...   May 27 2022, 05:58 PM
shredtherad   So it takes about 20 min's before this happen...   May 27 2022, 08:50 PM
wonkipop   factory workshop manual you can download. http:/...   May 27 2022, 08:47 PM
mgphoto   First test is simple, get a hand vacuum pump with ...   May 27 2022, 09:57 PM
GregAmy   First test is simple, get a hand vacuum pump with...   May 28 2022, 06:53 AM
shredtherad   First test is simple, get a hand vacuum pump wit...   May 28 2022, 08:57 AM
shredtherad   [quote name='mgphoto' post='3004625' date='May 27...   May 28 2022, 09:00 AM
Lockwodo   [quote name='GregAmy' post='3004653' date='May 28...   May 28 2022, 10:31 AM
shredtherad   First test is simple, get a hand vacuum pump with...   May 28 2022, 08:56 AM
brant   Can you hear the pump run when it’s acting up an...   May 29 2022, 06:56 AM
shredtherad   Can you hear the pump run when it’s acting up a...   May 29 2022, 08:31 AM
rhodyguy   This is a MittyvacII. You will know if the diaphra...   May 29 2022, 08:35 AM
shredtherad   This is a MittyvacII. You will know if the diaphr...   May 29 2022, 10:49 AM
shredtherad   All, thanks for the replies and insights I teste...   May 29 2022, 10:54 AM
brant   So that creates an ultra rich condition and the re...   May 29 2022, 12:40 PM
brant   There is also an O’ring inside to seal the MPS c...   May 30 2022, 09:04 AM
shredtherad   There is also an O’ring inside to seal the MPS ...   May 30 2022, 05:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:15 PM
