bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Plans to Megasquirt my car got delayed over the winter so my Webers will stay on for another summer. So, I finally hooked up my wideband to see if any adjustments are needed to keep the engine happy and safe until I can do the conversion.
The only real "problem" area is idle and low speed driving on the progression circuit where it is running too rich. It idles smooth and steady at 700 rpm with AFR of 12.3. That with idle mix screws ~ 2 turns off their seats. That's the leanest I can adjust and keep the engine happy. Just off idle at 20-40 mph @3000 rpm it goes even more rich to around 11.0 +/- 0.5. I don't think that's alarmingly rich but wasteful and I do get a bit of annoying surging/bucking driving below 30 mph. Current jetting is as follows: Venturi - 28 Emulsion tubes - F11 Main jet - 115 Correction Jet - 200 Idle jet - 50 I'm thinking I should reduce the idle jet but not sure by how much. I can get .047, .045, or .040. Any suggestions? I could also use some advice on mains and/or air correction jets. If I didn't plan to swap the carbs to FI, I'd try for a little leaner highway cruising mix for better economy and maybe flexibility. In limited testing running in good ranges for performance at the expense of economy - WOT ~12.5, Highway cruise ~13.5 but rarely goes above 14.0 even on downhill and decel. Weather is crappy here this weekend so I've only done a short drive in hilly conditions. I need to get it down in the valley for some long level runs to see where it settles. I think I can live with the numbers I'm seeing now, but do wonder what it will do when I attempt to cross a 10,000 ft. pass. I'd rather it not die of oxygen starvation if I attempt it. Any thoughts? BTW, I live at 6,000 ft. elevation so I'm not surprised it is running on the rich side with out of the box jetting. |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,095 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
1)Opening the throttle plates will expose the transition circuit and add more fuel and air. Changing the mixture screw at this point will have little to no effect on the fuel being pulled from the transition slots.
2)Opening the air bleeds will allow a little air into the (1)carb(like the screw on our Djets) This can be used to balance a bbl that is not in sync with another, in sync to the others or as an idle control to a lesser amount. 3)Timing can be used to raise and lower the idle speed as needed too. When you change you throttle plate location you need to reset your best lean mixture again on all 4 bbls |
bbrock |
1)Opening the throttle plates will expose the transition circuit and add more fuel and air. Changing the mixture screw at this point will have little to no effect on the fuel being pulled from the transition slots. 2)Opening the air bleeds will allow a little air into the (1)carb(like the screw on our Djets) This can be used to balance a bbl that is not in sync with another, in sync to the others or as an idle control to a lesser amount. 3)Timing can be used to raise and lower the idle speed as needed too. When you change you throttle plate location you need to reset your best lean mixture again on all 4 bbls (IMG:style_emoticons/default/agree.gif) My earlier point about setting the bypass screws 1/2 open to start as Tomlinsons suggests is that it would reduce the butterfly opening needed to achieve the desired idle. In which case, less likely to expose the the progression ports. I can also see how it could cause the lag that John mentioned on that Shoptalk thread since I suppose you could end up with the butterflies so closed at idle there is a bit of lag between squeezing the accelerator and exposing the first transition port. I'm not saying I think Tomlinsons' procedure is the right or wrong way to do it, just stating what the effect is. I actually don't think my idle speed screw is anywhere close to a half turn out but will follow the aircooled.net procedure to make sure. That procedure makes the most sense to me because you wind up with throttle plates precisely where they should be. |
Lo-Fi Version | Time is now: 12th September 2025 - 09:23 PM |
