> Fuel injection issues? Possibly run carbs?
bmtrnavsky
post Apr 19 2022, 01:52 PM
My 914 has been sidelined since 2012 for a number of reasons but was parked not running. Pulled it out of mothballs and hauled it over to the local vintage Porsche mechanic who said my impulse sender had no signal. He said he was unable to source parts for it and was unsure if replacing that part would get it back on the road his recommendation was to convert to Weber 40's. I'm not rich so I understand his hesitancy to open what could be a very expensive can of worms.
So here is where my questions start
I'm just looking for a solid running reliable car that I can drive on trips and maybe autocross 2-3x per year.
anyone have a source on the impulse senders? can they be rebuilt?
Is the Carb it advice good?
I have a basically stock 2.0 with hydraulic lifters and a very mild cam.
Will I have to change my cam to convert it?
what's the best carb? I have seen 34's 40's and 44's people seem to do all three are there pros and cons to each setup?
Can I get this conversion done for around $1500 in parts and is it a achievable project for an average mechanic? I suck with electrical but I have plenty of tools and am not afraid to learn as I go. I have done head gaskets and other mid level projects before.
ClayPerrine
post May 17 2022, 08:42 AM
My suggestion is to float test the single carb. Throw it in a lake. If it floats, use it on your car.
Now for some real advice... find a complete L-Jet system and put it back on the car. You will be much happier than the single pinto/weber carb in both performance and mileage.
Clay
914e
post Jun 1 2022, 11:45 AM
QUOTE(ClayPerrine @ May 17 2022, 07:42 AM) *
Clay
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
I feel the same about carbs.
bmtrnavsky   Fuel injection issues? Possibly run carbs?   Apr 19 2022, 01:52 PM
brant   which motor and injection system are on the car? ...   Apr 19 2022, 01:59 PM
bmtrnavsky   which motor and injection system are on the car? ...   Apr 19 2022, 02:25 PM
brant   which motor and injection system are on the car?...   Apr 19 2022, 02:56 PM
BK911   I swapped over to carbs for the same reason; parts...   Apr 19 2022, 02:01 PM
930cabman   I swapped over to carbs for the same reason; part...   Apr 20 2022, 06:06 AM
nditiz1   You can carb it! You will not need to change ...   Apr 19 2022, 02:08 PM
Superhawk996   . . . . local vintage Porsche mechanic who said m...   Apr 19 2022, 02:40 PM
SirAndy   Time for a new mechanic in my opinion :agree:   Apr 21 2022, 04:39 PM
brant   all of the FI parts are out there... even if it m...   Apr 19 2022, 02:49 PM
Superhawk996   On a more pleasant note: If you are limited on ...   Apr 19 2022, 02:52 PM
dr914@autoatlanta.com   keep the fuel injection call for advice, do not in...   Apr 19 2022, 02:53 PM
PCH   The good news: it's probably something really ...   Apr 19 2022, 04:53 PM
JamesM   I'm just looking for a solid running reliabl...   Apr 19 2022, 04:55 PM
Lockwodo   I'm a newby here and am working on getting the...   Apr 19 2022, 05:32 PM
mtndawg   I've owned a car with carbs and a car with sto...   Apr 19 2022, 05:40 PM
914werke   What hasn't been brought up (in this thread) t...   Apr 19 2022, 05:55 PM
burton73   All I can say is with my Porsche cars with FI, the...   Apr 19 2022, 06:22 PM
r_towle   Carbs FTW I do believe an impulse sender is what w...   Apr 19 2022, 07:06 PM
914_teener   Carbs FTW I do believe an impulse sender is what ...   May 26 2022, 06:10 PM
r_towle   Looking at your location quickly I found Modern Ai...   Apr 19 2022, 07:13 PM
emerygt350   It can only be the trigger points (although impuls...   Apr 19 2022, 07:22 PM
rhodyguy   Going carbs? Figure out which distributor you are ...   Apr 20 2022, 10:01 AM
Superhawk996   Before I add more, let me say I'm in the camp ...   Apr 20 2022, 12:37 PM
jdamiano   I have the stock FI, in a box in my shed in case a...   Apr 20 2022, 06:22 PM
Lockwodo   I have the stock FI, in a box in my shed in case ...   Apr 20 2022, 08:59 PM
ClayPerrine   You could always go aftermarket EFI... http://www...   Apr 21 2022, 06:08 AM
JamesM   You could always go aftermarket EFI... I know ...   Apr 21 2022, 01:24 PM
930cabman   How can you not like this setup? Budget $...   Apr 21 2022, 07:00 AM
rhodyguy   The 356 kit is $3495. Plus any options not in...   Apr 21 2022, 07:27 AM
DRPHIL914   @bmtrnavsky to the OP - i am guessing the impuls...   Apr 21 2022, 07:50 AM
GeorgeKopf   As for after market EFI, I was looking at these: ...   Apr 21 2022, 07:54 AM
DRPHIL914   As for after market EFI, I was looking at these: ...   Apr 21 2022, 09:08 AM
ClayPerrine   As for after market EFI, I was looking at these: ...   Apr 21 2022, 10:26 AM
GregAmy   Note I am successfully controlling idle in my 2L D...   Apr 21 2022, 01:57 PM
jdamiano   Carb kit. Use the 40s for a stock motor. http://ww...   Apr 21 2022, 04:20 PM
Ansbacher   My advice on carbs: 1. Don't oversize. 40s ar...   Apr 21 2022, 04:56 PM
Craigers17   If you end up converting to carbs, and decide upon...   Apr 21 2022, 06:55 PM
rjames   Once you read up on how the stock FI works and how...   Apr 22 2022, 08:08 AM
emerygt350   Once you read up on how the stock FI works and ho...   Apr 22 2022, 10:34 AM
bmtrnavsky   Ok it’s bad trigger points the thingy under the ...   Apr 30 2022, 09:07 AM
ndfrigi   Ok it’s bad trigger points the thingy under the...   Apr 30 2022, 09:18 AM
ClayPerrine   Ok it’s bad trigger points the thingy under the...   Apr 30 2022, 10:27 AM
pbanders   You've gotten a lot of advice and info here, I...   Apr 30 2022, 09:30 AM
emerygt350   Agree, 123ignition. One of the best things I have...   Apr 30 2022, 03:16 PM
r_towle   123 works to replace trigger points? How?   Apr 30 2022, 05:02 PM
BeatNavy   123 works to replace trigger points? How? Yes, t...   Apr 30 2022, 06:04 PM
nivekdodge   123 works to replace trigger points? How? Yes, ...   Apr 30 2022, 09:32 PM
ClayPerrine   [quote name='BeatNavy' post='2998774' date='Apr 3...   Apr 30 2022, 09:54 PM
nivekdodge   [quote name='BeatNavy' post='2998774' date='Apr ...   May 16 2022, 04:31 PM
emerygt350   Yep, just put the two leads from the distributor i...   Apr 30 2022, 06:16 PM
nditiz1   No The one you have is most likely for one with c...   May 16 2022, 07:19 PM
pbanders   FWIW, I just found four sets of used trigger conta...   May 16 2022, 07:43 PM
emerygt350   And worth every penny.... I can always go back to...   May 16 2022, 08:42 PM
ClayPerrine   My suggestion is to float test the single carb. T...   May 17 2022, 08:42 AM
wonkipop   My suggestion is to float test the single carb. ...   May 26 2022, 07:03 AM
914e   My suggestion is to float test the single carb. ...   Jun 1 2022, 11:45 AM
bmtrnavsky   When I looked at the 123 distributor it looked lik...   May 25 2022, 08:39 PM
ClayPerrine   When I looked at the 123 distributor it looked li...   May 26 2022, 05:33 AM
BeatNavy   No, you don't keep the trigger points. The tr...   May 26 2022, 05:32 AM
Jake Raby   That carburetor (or any single) fitted to these ...   May 26 2022, 09:23 AM
ClayPerrine   That carburetor (or any single) fitted to these...   May 26 2022, 11:03 AM
Superhawk996   I rip them off, and crush them with my bulldozer...   May 26 2022, 11:05 AM
rjames   :rotfl: :first:   May 26 2022, 09:59 AM
emerygt350   I once ordered a strong beer at a mass bar and the...   May 26 2022, 06:16 PM
bmtrnavsky   Are the any vendors on The World who Sell this and...   May 31 2022, 01:05 PM
emerygt350   Trigger points are NLA, I think there are some fol...   May 31 2022, 07:13 PM
Lockwodo   Trigger points are NLA, I think there are some fo...   May 31 2022, 08:27 PM
Superhawk996   [quote name='emerygt350' post='3005553' date='May...   Jun 1 2022, 05:33 AM
emerygt350   Just too many advantages to the 123. Although you...   Jun 1 2022, 10:26 AM
Superhawk996   Just too many advantages to the 123. Although yo...   Jun 1 2022, 10:47 AM
JeffBowlsby   My comments about the 123 trigger points. Some ma...   Jun 1 2022, 12:57 PM
emerygt350   Definitely concerns of importance, however, my car...   Jun 1 2022, 05:58 PM
bmtrnavsky   I’m sold on 123 distributor… is there a vendor...   Jun 3 2022, 11:59 PM
Lockwodo   I’m sold on 123 distributor… is there a vendo...   Jun 4 2022, 05:37 PM
emerygt350   I got mine from tangerine racing but I am not sure...   Jun 4 2022, 04:41 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:03 AM
