bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Plans to Megasquirt my car got delayed over the winter so my Webers will stay on for another summer. So, I finally hooked up my wideband to see if any adjustments are needed to keep the engine happy and safe until I can do the conversion.
The only real "problem" area is idle and low speed driving on the progression circuit where it is running too rich. It idles smooth and steady at 700 rpm with AFR of 12.3. That with idle mix screws ~ 2 turns off their seats. That's the leanest I can adjust and keep the engine happy. Just off idle at 20-40 mph @3000 rpm it goes even more rich to around 11.0 +/- 0.5. I don't think that's alarmingly rich but wasteful and I do get a bit of annoying surging/bucking driving below 30 mph. Current jetting is as follows: Venturi - 28 Emulsion tubes - F11 Main jet - 115 Correction Jet - 200 Idle jet - 50 I'm thinking I should reduce the idle jet but not sure by how much. I can get .047, .045, or .040. Any suggestions? I could also use some advice on mains and/or air correction jets. If I didn't plan to swap the carbs to FI, I'd try for a little leaner highway cruising mix for better economy and maybe flexibility. In limited testing running in good ranges for performance at the expense of economy - WOT ~12.5, Highway cruise ~13.5 but rarely goes above 14.0 even on downhill and decel. Weather is crappy here this weekend so I've only done a short drive in hilly conditions. I need to get it down in the valley for some long level runs to see where it settles. I think I can live with the numbers I'm seeing now, but do wonder what it will do when I attempt to cross a 10,000 ft. pass. I'd rather it not die of oxygen starvation if I attempt it. Any thoughts? BTW, I live at 6,000 ft. elevation so I'm not surprised it is running on the rich side with out of the box jetting. |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
You will want to tune as though everything is in place, so distro vac in use. I believe the most ideal is with the air filters in place as well. They have a minor and probably almost non-existent impact.
Also not going to get into any debates with Dizzy's BUT SVDA style ones do have benefits to the smoothness of off idle. I'm guessing you have one since you are talking about the vac. 800 seems low to me. I usually tune carbs to 950-1000. |
bbrock |
You will want to tune as though everything is in place, so distro vac in use. I believe the most ideal is with the air filters in place as well. They have a minor and probably almost non-existent impact. Also not going to get into any debates with Dizzy's BUT SVDA style ones do have benefits to the smoothness of off idle. I'm guessing you have one since you are talking about the vac. 800 seems low to me. I usually tune carbs to 950-1000. Thanks. Tuning with dizzy hooked up and air cleaner on makes the most sense to me, but I'm still wrapping my head around the idea that larger idle jets will lean the idle circuit so what do I know? (IMG:style_emoticons/default/screwy.gif) I'm actually running the stock DVDA dizzy with the trigger point opening blocked off. I tried a 050 but didn't like it. Bought an SVDA and it was good but I actually liked the response of the stock dizzy a little better and having vacuum retard for lower idle and emissions was the tie breaker. I've been very happy with it. Maybe that will change after I get the idle leaned out. |
Lo-Fi Version | Time is now: 12th September 2025 - 09:25 PM |
