bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Plans to Megasquirt my car got delayed over the winter so my Webers will stay on for another summer. So, I finally hooked up my wideband to see if any adjustments are needed to keep the engine happy and safe until I can do the conversion.
The only real "problem" area is idle and low speed driving on the progression circuit where it is running too rich. It idles smooth and steady at 700 rpm with AFR of 12.3. That with idle mix screws ~ 2 turns off their seats. That's the leanest I can adjust and keep the engine happy. Just off idle at 20-40 mph @3000 rpm it goes even more rich to around 11.0 +/- 0.5. I don't think that's alarmingly rich but wasteful and I do get a bit of annoying surging/bucking driving below 30 mph. Current jetting is as follows: Venturi - 28 Emulsion tubes - F11 Main jet - 115 Correction Jet - 200 Idle jet - 50 I'm thinking I should reduce the idle jet but not sure by how much. I can get .047, .045, or .040. Any suggestions? I could also use some advice on mains and/or air correction jets. If I didn't plan to swap the carbs to FI, I'd try for a little leaner highway cruising mix for better economy and maybe flexibility. In limited testing running in good ranges for performance at the expense of economy - WOT ~12.5, Highway cruise ~13.5 but rarely goes above 14.0 even on downhill and decel. Weather is crappy here this weekend so I've only done a short drive in hilly conditions. I need to get it down in the valley for some long level runs to see where it settles. I think I can live with the numbers I'm seeing now, but do wonder what it will do when I attempt to cross a 10,000 ft. pass. I'd rather it not die of oxygen starvation if I attempt it. Any thoughts? BTW, I live at 6,000 ft. elevation so I'm not surprised it is running on the rich side with out of the box jetting. |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
Jumping in late to this convo, but I’m going through similar analysis paralysis issues on my 6. Had a single wideband per PO in banks 1,2,3, when tuning by ear seemed ok, but felt I was missing something. Plugs on 4,5,6 told me I was running rich. I installed 2nd wideband on the 4,5,6 side and sure enough, tune was not balanced at all. Got it running better, then started to wonder about each hole…..
Bought this… https://www.gunson.co.uk/product/G4074/Colo...e-Plug-Kit-14mm Now I’m feeling much better about each cylinder… |
bbrock |
Jumping in late to this convo, but I’m going through similar analysis paralysis issues on my 6. Had a single wideband per PO in banks 1,2,3, when tuning by ear seemed ok, but felt I was missing something. Plugs on 4,5,6 told me I was running rich. I installed 2nd wideband on the 4,5,6 side and sure enough, tune was not balanced at all. Got it running better, then started to wonder about each hole….. Bought this… https://www.gunson.co.uk/product/G4074/Colo...e-Plug-Kit-14mm Now I’m feeling much better about each cylinder… I forgot about the color tune kits. Remember seeing someone post about them a year or so ago and thought they looked useful. Since I'll ultimately be megasquirting this car, I'll call it good with the single wideband for carb tuning, but don't think I haven't fantasized about closed loop with individual sensors with the EFI (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 12th September 2025 - 09:25 PM |
