> Need Carb Jet Guidance, Weber 40 IDFs
bbrock
post May 29 2022, 05:35 PM
Plans to Megasquirt my car got delayed over the winter so my Webers will stay on for another summer. So, I finally hooked up my wideband to see if any adjustments are needed to keep the engine happy and safe until I can do the conversion.
The only real "problem" area is idle and low speed driving on the progression circuit where it is running too rich. It idles smooth and steady at 700 rpm with AFR of 12.3. That with idle mix screws ~ 2 turns off their seats. That's the leanest I can adjust and keep the engine happy. Just off idle at 20-40 mph @3000 rpm it goes even more rich to around 11.0 +/- 0.5. I don't think that's alarmingly rich but wasteful and I do get a bit of annoying surging/bucking driving below 30 mph.
Current jetting is as follows:
Venturi - 28
Emulsion tubes - F11
Main jet - 115
Correction Jet - 200
Idle jet - 50
I'm thinking I should reduce the idle jet but not sure by how much. I can get .047, .045, or .040. Any suggestions?
I could also use some advice on mains and/or air correction jets. If I didn't plan to swap the carbs to FI, I'd try for a little leaner highway cruising mix for better economy and maybe flexibility. In limited testing running in good ranges for performance at the expense of economy - WOT ~12.5, Highway cruise ~13.5 but rarely goes above 14.0 even on downhill and decel. Weather is crappy here this weekend so I've only done a short drive in hilly conditions. I need to get it down in the valley for some long level runs to see where it settles. I think I can live with the numbers I'm seeing now, but do wonder what it will do when I attempt to cross a 10,000 ft. pass. I'd rather it not die of oxygen starvation if I attempt it. Any thoughts?
BTW, I live at 6,000 ft. elevation so I'm not surprised it is running on the rich side with out of the box jetting.
nditiz1
post Jun 6 2022, 01:58 PM
While I cannot disagree with Phil as his knowledge on all things far surpasses mine. Got more years on me Phil, but im still learning. Anyhow, I can't understand how the air corrector has any effect on the idle circuit. You can drive around with the main stacks gone. There would be no air corrector.
bbrock   Need Carb Jet Guidance   May 29 2022, 05:35 PM
Superhawk996   Warning: you’re measuring using an electron mic...   May 30 2022, 03:52 AM
Superhawk996   lG1OHoqeQTU I think think you’ll be fine on car...   May 30 2022, 04:21 AM
rfinegan   if you are at 2 turns, you are running on the lean...   May 30 2022, 07:05 AM
914Toy   What size is your engine? Have you adjusted/balanc...   May 30 2022, 08:40 AM
NARP74   My car was adjusted at a much lower altitude then ...   May 30 2022, 08:53 AM
bbrock   Thanks all. The engine is stock 2L (1971cc) with ...   May 30 2022, 09:39 AM
Superhawk996   What surprises me is that it doesn't lean ou...   May 30 2022, 11:32 AM
nditiz1   I'm interested if they are still available. ...   May 30 2022, 10:32 AM
bbrock   I'm interested if they are still available. ...   May 30 2022, 11:06 AM
rhodyguy   Slight bucking at low speeds? How low and @ what R...   May 30 2022, 11:23 AM
bbrock   Slight bucking at low speeds? How low and @ what ...   May 30 2022, 11:54 AM
Superhawk996   I assume most city driving is happening on idle a...   May 30 2022, 01:50 PM
bbrock   [quote name='bbrock' post='3005153' date='May 30 ...   May 30 2022, 02:28 PM
NARP74   They were originally tuned at a much lower altitud...   May 30 2022, 05:03 PM
bbrock   They were originally tuned at a much lower altitu...   May 30 2022, 08:06 PM
nditiz1   Another thing to look at is the accelerator pump. ...   May 30 2022, 08:11 PM
bbrock   Another thing to look at is the accelerator pump....   May 30 2022, 08:22 PM
Superhawk996   :popcorn: Will be watching to see how this turns...   May 31 2022, 05:01 AM
bbrock   Nothing new to add but I did some reading (yes, da...   May 31 2022, 07:53 AM
Superhawk996   In theory, opening the bypasses could drop the bu...   May 31 2022, 08:37 AM
bbrock   Part of the problem with opening the bypass as yo...   May 31 2022, 02:02 PM
rfinegan   You need to get off your transition slots it they ...   May 31 2022, 08:45 AM
bbrock   You need to get off your transition slots it they...   May 31 2022, 02:18 PM
rfinegan   1)Opening the throttle plates will expose the tran...   May 31 2022, 02:20 PM
bbrock   1)Opening the throttle plates will expose the tra...   May 31 2022, 02:57 PM
IronHillRestorations   I don't think you'll hurt anything by tryi...   May 31 2022, 03:27 PM
nditiz1   I'm not sure I agree with this. The air byp...   May 31 2022, 07:09 PM
bbrock   I'm not sure I agree with this. The air by...   May 31 2022, 07:50 PM
Superhawk996   :popcorn:   Jun 1 2022, 05:43 AM
bbrock   Spent time over lunch and after work meticulously ...   Jun 1 2022, 07:39 PM
r_towle   Bigger idle jet, bigger correction jet. If you wan...   Jun 1 2022, 07:57 PM
bbrock   Another dumb question here but should I be setting...   Jun 2 2022, 09:50 AM
nditiz1   You will want to tune as though everything is in p...   Jun 2 2022, 10:43 AM
bbrock   You will want to tune as though everything is in ...   Jun 2 2022, 12:55 PM
nditiz1   I'm not understanding how increasing idle jet ...   Jun 2 2022, 02:14 PM
bbrock   I'm not understanding how increasing idle jet...   Jun 2 2022, 02:51 PM
infraredcalvin   Jumping in late to this convo, but I’m going thr...   Jun 2 2022, 02:39 PM
bbrock   Jumping in late to this convo, but I’m going th...   Jun 2 2022, 02:58 PM
rfinegan   You can always open the .45 to .475 if they are to...   Jun 2 2022, 03:09 PM
nditiz1   Just ordered 2 of those colortune's last week....   Jun 2 2022, 03:16 PM
infraredcalvin   Just ordered 2 of those colortune's last week...   Jun 2 2022, 07:15 PM
rfinegan   Did you mention what your base timing is set at? A...   Jun 2 2022, 03:26 PM
bbrock   You can always open the .45 to .475 if they are t...   Jun 2 2022, 03:54 PM
930cabman   I have been following this to a certain degree as ...   Jun 2 2022, 05:34 PM
bbrock   Did you mention the car is running good? Maybe le...   Jun 2 2022, 06:45 PM
nditiz1   With the numbers you provided on the AFR were your...   Jun 2 2022, 06:18 PM
bbrock   With the numbers you provided on the AFR were you...   Jun 2 2022, 06:37 PM
bbrock   BTW, the 3200 rpm transition squares with my brief...   Jun 2 2022, 06:47 PM
bbrock   I might have made some progress today. The new je...   Jun 4 2022, 08:37 PM
930cabman   Where are your mixture screws with the 45's, 5...   Jun 5 2022, 09:02 AM
rhodyguy   I don't understand why you're trying to ac...   Jun 5 2022, 10:25 AM
bbrock   Getting dialed in a bit more. Swapped out the 200 ...   Jun 5 2022, 11:41 AM
rhodyguy   you only measure the flow on the 2 front Venturi f...   Jun 5 2022, 12:59 PM
bbrock   you only measure the flow on the 2 front Venturi ...   Jun 5 2022, 03:58 PM
bbrock   Okay, it might be time to eat crow. I managed to ...   Jun 6 2022, 10:49 AM
Superhawk996   To my surprise, the idle leaned out. I don...   Jun 6 2022, 12:42 PM
bbrock   To my surprise, the idle leaned out. I don...   Jun 6 2022, 02:58 PM
Superhawk996   So in other words... it IS sorcery! :rotfl: ...   Jun 6 2022, 04:18 PM
930cabman   Something still puzzling is that Tomlinsons and AC...   Jun 6 2022, 11:42 AM
IronHillRestorations   Sounds like you are making progress. You might wa...   Jun 6 2022, 12:24 PM
bbrock   I would be curious if either was using any sort o...   Jun 6 2022, 12:53 PM
nditiz1   While I cannot disagree with Phil as his knowledge...   Jun 6 2022, 01:58 PM
Superhawk996   While I cannot disagree with Phil as his knowledg...   Jun 6 2022, 03:52 PM
bbrock   The only thing I've really learned over the y...   Jun 6 2022, 05:24 PM
930cabman   The only thing I've really learned over the ...   Jun 6 2022, 06:00 PM
nditiz1   Whoa! Sure carbs are finicky to tune but no o...   Jun 6 2022, 06:20 PM
bbrock   Whoa! Sure carbs are finicky to tune but no ...   Jun 6 2022, 09:30 PM
GBX0073   Great to see this thread on Carb tuning and the 91...   Jun 6 2022, 09:50 PM
GBX0073   Went Ahead and ordered Innovate Motorsports 39350...   Jun 7 2022, 11:35 AM
bbrock   Well, I'm not sure if I took a step backward o...   Jun 7 2022, 09:10 PM
Jake Raby   Most carb issues are really ignition issues. If 50...   Jun 7 2022, 09:49 PM
bbrock   Most carb issues are really ignition issues. If 5...   Jun 7 2022, 10:16 PM
Jake Raby   Most carb issues are really ignition issues. If ...   Jun 8 2022, 09:57 AM
930cabman   Where are your float levels?   Jun 9 2022, 05:26 PM
bbrock   Where are your float levels? I've checked t...   Jun 9 2022, 08:35 PM
bbrock   Well I think I can finally declare victory. There...   Jul 9 2022, 04:51 PM
930cabman   Well I think I can finally declare victory. Ther...   Jul 11 2022, 02:54 PM
bbrock   I was unaware of an idle jet 47? (correction, Pie...   Jul 11 2022, 11:24 PM
- Lo-Fi Version Time is now: 12th September 2025 - 09:25 PM
