Another 6 external oil cooler thread, Yes I have been reading build threads |
nditiz1 |
Jun 5 2022, 08:14 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Ok so the temps in the 6 are not what I'd like them to be. Could it be tuning maybe, but the 2.4 is running pretty good and the WB says I'm on the rich side.
I purchased a Mocal t stat. I had already purchased a stock 911 one, but it's bulky so I think I'll sell it. Why do some run the lines up the passenger and some up the driver? Is it because the cooler up front only goes one-way? Just preference? Where is the best mounting spot? Pics would be helpful. Andy put his inside the chassis. I'm looking for a more general mounting spot. Can it be installed up in the frunk as I have seen on others? What's the drawback there? Thanks and sorry in advance for the millionth ask. I might do something similar to tomeric, but was just curious about these other things first. |
nditiz1 |
Jun 6 2022, 04:49 PM
Air diffuser is should be in place. I say should because the alternator was swapped over from my other engine and I did not perform that swap. I don't see why the PO would leave it off, but then again wouldn't think he'd leave a blue towel in it either.
The flaps I was referencing were under the chassis. I have seen some use them on their 6 and some not. As far as the seals, while new, some of the seals are just touching. Let me grab some tape for the next run. I pulled plug 5 and the plug looked gray, so lean. The colortunes just came in so I will be getting the mixtures perfect. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:58 PM |
