What just happened ?, Final update 6/14/22 |
jim_hoyland |
Jun 12 2022, 01:00 PM
Get that VIN ? Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I was humming along PCH and stopped at the 7-11. As I left the 7-11; put the car in firs, let outage clutch. I har this sound like the tranny popped out of gear. After that, no selected gear did anything. Engine runs fine, just can't drive.
Tjis was Friday, had the car towed to PCH garage, a couple of blocks away. Has anyone had this happen to them ? 914Toy,Keith, suggested several possibilities: 1. Cone screws at shifter rods 2. Roll pin in the short shift lever at the rear console 3. Inspect/turn each drive shaft independently and listen for noises and note motion The car has a recent Tangerine rear shift console modification. Any experience and/or suggestions will be appreciated. @Dr Evil |
Dave_Darling |
Jun 13 2022, 01:05 PM
You said when the one wheel turns the other does not. Did you check to see if the axles were turning? The outboard CV joint can come loose or fail such that it will not transmit any power, but still be in the right location because it rests in the hole through the trailing arm.
Definitely worth taking a minute to check both sides before you tear the transmission apart... --DD |
Lo-Fi Version | Time is now: 16th June 2024 - 02:36 PM |
