Venturi on Weber 40s?, Venturi advice |
Boothy |
Jun 21 2022, 07:10 AM
Member Group: Members Posts: 88 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Morning All,
I've searched but haven't located the info on venturi sizes for Weber 40s. I have a 1.7 with a big bore and CB carb cam. The Weber I have came with a bag of venturis so I'm trying to determine the right size. Thanks in advance! |
nditiz1 |
Jun 21 2022, 11:05 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
28's will be fine. I have run them up to a 2056 and were still fine. The main thing that it will do is move your power band. If when you are running up the tach you get to a part where your RPM increases, but you don't feel like you have any more power "flat" then you would want to increase the vents.
930cabman |
Jun 21 2022, 11:33 AM
Advanced Member Group: Members Posts: 3,147 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
28's will be fine. I have run them up to a 2056 and were still fine. The main thing that it will do is move your power band. If when you are running up the tach you get to a part where your RPM increases, but you don't feel like you have any more power "flat" then you would want to increase the vents. (IMG:style_emoticons/default/agree.gif) start with 28's and go from there. What condition is the engine in? compression #'s and/or leakdown #'s |
Lo-Fi Version | Time is now: 10th June 2024 - 02:13 AM |
