Dumb question about wideband O2 sensor, Is it okay to drive with it disconnected? |
bbrock |
Jun 26 2022, 12:25 PM
Kind of an odd question but I have a wideband O2 sensor installed I've been using to dial in carbs using my laptop with Logger3 installed for the gauge. I'm going to drive the car on a moderately long trip next week and don't want to leave the cable snaked through the engine lid and targa top when I drive.
I think it was McMark who said the sensors don't like to be installed and uninstalled too many times so I'm wondering if there is any harm in leaving the sensor in place but disconnecting from power and tying the cable out of the way in the engine bay, or should I remove the sensor completely. Is there any harm in leaving the sensor installed by not connected? |
Mark Henry |
Jun 27 2022, 11:33 AM
Only two choices, take it out or leave it running, you have to have power to the sensor.
McMark is correct, every time you remove a lambda you risk ruining it. For temporary set ups remove the sensor as soon as you're done, if you leave it in too long it will get stuck. Once it's really stuck you will likely pooch the sensor when removing it. If you're installing or replacing a sensor it's good practice to chase the threads and use the proper socket, both tap, socket and bung plug are available at your FLAPS. Always use anti-seize on the threads, but be careful not to get any of it on the sensor tip. Heh-heh I said 'bung plug' (IMG:style_emoticons/default/sheeplove.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 04:23 PM |
