Dual Carb with fuel return line |
ndfrigi |
Jun 29 2022, 01:31 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hello Teeners! Is there anyone can share any pictures how they do a return fuel line especially on the carb side?
Since I will be replacing my fuel lines to SS and removing my fuel tank to clean, much as well prep everything with return line. I have Weber 36 Idf with 32vent Thank you! |
bbrock |
Jun 29 2022, 07:27 AM
I have mine set up in the stock configuration using a stock (EFI) fuel pump. Works great. Another advantage of running a return line is that the fuel tank was designed for a return line to keep the reserve fuel bowl full. Without the return line, you are likely to start sucking air before the reserve fuel is depleted.
Lo-Fi Version | Time is now: 1st June 2024 - 03:42 AM |
