> Dual Carb with fuel return line
ndfrigi
post Jun 29 2022, 01:31 AM
Hello Teeners! Is there anyone can share any pictures how they do a return fuel line especially on the carb side?
Since I will be replacing my fuel lines to SS and removing my fuel tank to clean, much as well prep everything with return line.
I have Weber 36 Idf with 32vent
Thank you!
bbrock
post Jun 29 2022, 07:27 AM
I have mine set up in the stock configuration using a stock (EFI) fuel pump. Works great. Another advantage of running a return line is that the fuel tank was designed for a return line to keep the reserve fuel bowl full. Without the return line, you are likely to start sucking air before the reserve fuel is depleted.
CCE
post Jun 29 2022, 08:00 AM
CCE
QUOTE(bbrock @ Jun 29 2022, 08:27 AM) *
Good to know, I have no return, will be aware to have always gas…
I also installed “AN fittings” (CB performance)
bbrock
post Jun 29 2022, 08:10 AM
QUOTE(CCE @ Jun 29 2022, 08:00 AM) *
Near as I can tell, the reserve bowl full keeps the last bit of fuel from sloshing around in corners to keep the pickup tube submerged. I'm guessing keeping the g-forces down would also get the last bit of gas to the carbs.
ndfrigi   Dual Carb with fuel return line   Jun 29 2022, 01:31 AM
930cabman   I have never ran a return line with a carb setup, ...   Jun 29 2022, 04:54 AM
brant   There is a diagram showing multiple ways to plumb ...   Jun 29 2022, 05:37 AM
brant   Here I’m using B E is a match to how the facto...   Jun 29 2022, 05:49 AM
bbrock   I have mine set up in the stock configuration usin...   Jun 29 2022, 07:27 AM
CCE   I have mine set up in the stock configuration usi...   Jun 29 2022, 08:00 AM
bbrock   I have mine set up in the stock configuration us...   Jun 29 2022, 08:10 AM
GregAmy   Unless the tanks differ, the part in the center is...   Jun 29 2022, 08:33 AM
bbrock   Unless the tanks differ, the part in the center i...   Jun 29 2022, 11:17 PM
Mark Henry   I tried but ran into issues with the small return ...   Jun 29 2022, 08:48 AM
nathanxnathan   I have always used the Holley pressure regulator (...   Jun 29 2022, 08:52 AM
NARP74   Remember OP said carbs. This is a 50/50 6 hour ar...   Jun 29 2022, 08:58 AM
GregAmy   The Webers (and Dells) do not offer an in/out port...   Jun 29 2022, 09:05 AM
Mark Henry   The Webers (and Dells) do not offer an in/out por...   Jun 29 2022, 11:30 AM
bbrock   The Webers (and Dells) do not offer an in/out por...   Jun 30 2022, 07:44 AM
nathanxnathan   I'm running this Malpassi bypass regulator. ...   Jun 30 2022, 10:53 AM
9146C   I just went through an exercise on my 2.7L six (wi...   Jun 29 2022, 10:28 AM
nathanxnathan   The Holley regulator was able to reduce the press...   Jun 29 2022, 11:17 AM
CCE   The Holley regulator was able to reduce the pres...   Jun 29 2022, 11:38 AM
nathanxnathan   In my case I had no need for the regulator, I in...   Jun 29 2022, 11:51 AM
BK911   I vote for option D. With a pmo style regulator.   Jun 29 2022, 10:34 AM
ndfrigi   Thank you everyone for all the responses!   Jun 29 2022, 04:01 PM
Front yard mechanic   Ok I'm an idiot what is the key to the diagram...   Jun 29 2022, 09:14 PM
ndfrigi   Ok I'm an idiot what is the key to the diagra...   Jun 29 2022, 11:39 PM
Front yard mechanic   Ok I'm an idiot what is the key to the diagr...   Jun 30 2022, 06:13 AM
NARP74   Same question for @BBrock and which configuratio...   Jun 30 2022, 11:17 AM
slivel   My configuration is: [*]Tank [*]Filter [*]Pump [*]...   Jun 30 2022, 11:48 AM
bbrock   [quote name='bbrock' post='3012264' date='Jun 30 ...   Jun 30 2022, 11:37 PM
bbrock   Same question for [b]@[url=http://www.914world....   Jul 2 2022, 10:34 AM
- Lo-Fi Version Time is now: 25th May 2026 - 08:15 AM
