Dual Carb with fuel return line |
ndfrigi |
Jun 29 2022, 01:31 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hello Teeners! Is there anyone can share any pictures how they do a return fuel line especially on the carb side?
Since I will be replacing my fuel lines to SS and removing my fuel tank to clean, much as well prep everything with return line. I have Weber 36 Idf with 32vent Thank you! |
Mark Henry |
Jun 29 2022, 08:48 AM
I tried but ran into issues with the small return pipe and the pressure of the FI fuel pump with a PMO regulator. The FI pump was making 5-6psi just with the return line restriction making it impossible to get the 3-4 psi for the carbs. The solution would be to run a larger return line. FYI a larger return tube is recommended for a return system, I think the small OE tube is fine for FI, only low pressure carbs run into this issue.
Another possible solution was to run a Holley V8 pump that runs at 7-10lbs. At this time I was trying to get my teen running for a show, so I slapped a low pressure pump on (that I had) with no return and it's been that way ever since. |
Lo-Fi Version | Time is now: 6th June 2024 - 12:40 PM |
