| ndfrigi |
Jun 29 2022, 01:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,983 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Hello Teeners! Is there anyone can share any pictures how they do a return fuel line especially on the carb side?
Since I will be replacing my fuel lines to SS and removing my fuel tank to clean, much as well prep everything with return line. I have Weber 36 Idf with 32vent Thank you! ![]() ![]() |
| NARP74 |
Jun 29 2022, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Remember OP said carbs. This is a 50/50 6 hour argument topic. I have seen compelling info from prominent people on both sides.
One question I have is that most setups go from the filter/pump straight to the 3/4 carbs and then to the 1/2 carbs. Doesn't that just give the 1/2 carbs what is left over from the 3/4 carbs? Wouldn't a Tee to the feed side of the carbs be beneficial and then a return from the 1/2 carbs if you want to? Would be interesting to see fuel pressures on both sides of that single feed line. |
ndfrigi Dual Carb with fuel return line Jun 29 2022, 01:31 AM
930cabman I have never ran a return line with a carb setup, ... Jun 29 2022, 04:54 AM
brant There is a diagram showing multiple ways to plumb ... Jun 29 2022, 05:37 AM
brant Here
I’m using B
E is a match to how the facto... Jun 29 2022, 05:49 AM
bbrock I have mine set up in the stock configuration usin... Jun 29 2022, 07:27 AM
CCE
I have mine set up in the stock configuration usi... Jun 29 2022, 08:00 AM
bbrock
I have mine set up in the stock configuration us... Jun 29 2022, 08:10 AM
GregAmy Unless the tanks differ, the part in the center is... Jun 29 2022, 08:33 AM
bbrock
Unless the tanks differ, the part in the center i... Jun 29 2022, 11:17 PM
Mark Henry I tried but ran into issues with the small return ... Jun 29 2022, 08:48 AM
nathanxnathan I have always used the Holley pressure regulator (... Jun 29 2022, 08:52 AM
GregAmy The Webers (and Dells) do not offer an in/out port... Jun 29 2022, 09:05 AM
Mark Henry
The Webers (and Dells) do not offer an in/out por... Jun 29 2022, 11:30 AM
bbrock
The Webers (and Dells) do not offer an in/out por... Jun 30 2022, 07:44 AM
nathanxnathan
I'm running this Malpassi bypass regulator. ... Jun 30 2022, 10:53 AM
9146C I just went through an exercise on my 2.7L six (wi... Jun 29 2022, 10:28 AM
nathanxnathan
The Holley regulator was able to reduce the press... Jun 29 2022, 11:17 AM
CCE
The Holley regulator was able to reduce the pres... Jun 29 2022, 11:38 AM
nathanxnathan
In my case I had no need for the regulator, I in... Jun 29 2022, 11:51 AM
BK911 I vote for option D.
With a pmo style regulator. Jun 29 2022, 10:34 AM
ndfrigi Thank you everyone for all the responses! Jun 29 2022, 04:01 PM
Front yard mechanic Ok I'm an idiot what is the key to the diagram... Jun 29 2022, 09:14 PM
ndfrigi
Ok I'm an idiot what is the key to the diagra... Jun 29 2022, 11:39 PM
Front yard mechanic
Ok I'm an idiot what is the key to the diagr... Jun 30 2022, 06:13 AM
NARP74 Same question for @BBrock and which configuratio... Jun 30 2022, 11:17 AM
slivel My configuration is:
[*]Tank
[*]Filter
[*]Pump
[*]... Jun 30 2022, 11:48 AM
bbrock
[quote name='bbrock' post='3012264' date='Jun 30 ... Jun 30 2022, 11:37 PM
bbrock
Same question for [b]@[url=http://www.914world.... Jul 2 2022, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 08:15 AM |
