Dual Carb with fuel return line |
ndfrigi |
Jun 29 2022, 01:31 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hello Teeners! Is there anyone can share any pictures how they do a return fuel line especially on the carb side?
Since I will be replacing my fuel lines to SS and removing my fuel tank to clean, much as well prep everything with return line. I have Weber 36 Idf with 32vent Thank you! |
bbrock |
Jun 30 2022, 11:37 PM
I'm running this Malpassi bypass regulator. So far it has worked perfectly holding the pressure at the carb at a steady 3.5 psi. It has been so steady, that I finally pulled the pressure gauge after monitoring pressure for 3K miles without seeing any variation in pressure at all. I'm running SS lines. The important key is using a bypass regulator that bleeds off enough volume of fuel from the supply to maintain pressure rather than choke down pressure like in a typical dead end regulator. I almost went the PMO route because it is supposed to do the same thing, but now glad I didn't after reading Mark's post. Are you using the "boost reference" port or just plug it and it works as just a regulator with a bypass? I just left the "boost reference" port open. I believe that is what the instructions specified if it wasn't being used. And yes, it works just as a bypass regulator in that configuration. I believe I'm using option C, but it might be D with a Tee just after the regulator output. I'll check tomorrow and confirm. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:17 AM |
