HELP I dont want to pull the heads, You have seen this problem B/4 |
spare time toys |
Jan 13 2005, 12:36 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I took the exhaust manifolds off the 928 engine today. I posted how at one point someone tried to seal the rear ports with JB weld. Rick posted a shot of a stud he welded a nut on. Well when I got the manifolds out of the way I find the studs broken off below the surface of the port (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Would you try a left hand drill bit and an EZ out or take the heads off and a quick trip to a shop? Here is the problem as I first found it.
Attached image(s) |
Mueller |
Jan 13 2005, 12:39 PM
it depend on how good your are with a drill bit (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
you could always get a dremel and slowly grind out the stud to weaken it and then try the EZ out method.... |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:48 AM |
