problem with my 1975 2.0 d-jet running fine then died, it was running great and then... |
buck toenges |
Jun 30 2022, 06:09 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I have a 75 2.0 d-jet. i turn the key about 4 times to get the fuel pump sending gas to the engine. Starts right up. it idles a little low to begin with but then idles about 1000 rpm after 5min. So I decided to take a drive. running great down the highway no issues what so ever. After about 25 miles up the road engine dies. Battery is fine and the starter works well, not a battery issue. I can't restart it. Had to have it towed back home. Let engine cool down but still won't start. Fuel pump engages but no start. Shot some starting fluid in throttle body but again no start.
I know my fuel injection harness is not the best but it wasn't good before today. Looking on line I think it might be a cht sensor issue. Saw this online https://www.youtube.com/watch?v=fbmanDTIun8 They tested the cht to ecu and found out it was a bad cht. Once they changed it their car fired right up. I haven't checked the fuel pressure, I haven't checked the injectors, I did check spark and I have it on the sparkplugs. I shot some starting fluid in the spark plug hole and no start. Any ideas? It is funny that it was running great and then died. Buck |
Dave_Darling |
Jul 5 2022, 07:41 PM
If the CHT is unplugged, the FI sees that as Super Duper Ultra Cold and adds a ton of fuel. That's usually too much for the engine to start.
If the mixture is super duper rich, adding starter fluid (which acts kind of like fuel) won't help it to start. If you short the CHT lead to ground, does the car want to start then? --DD |
buck toenges |
Jul 6 2022, 07:23 AM
If the CHT is unplugged, the FI sees that as Super Duper Ultra Cold and adds a ton of fuel. That's usually too much for the engine to start. If the mixture is super duper rich, adding starter fluid (which acts kind of like fuel) won't help it to start. If you short the CHT lead to ground, does the car want to start then? --DD I went out last night and ground out the FI lead to the cht wire. Shot some starting fluid in and the engine started right up. So the lesson is if your engine doesn't start and you think it might be the cht, disconnected the cht from the FI harness, ground out the cht lead and shoot some starting fluid into the throttle body. If engine starts than replace cht. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:54 PM |
