Volt meter question, Secondary added question |
Menmojo |
Jul 26 2022, 08:14 PM
Porsche addict Group: Members Posts: 49 Joined: 7-July 15 From: Midwest Member No.: 18,929 Region Association: None |
I’m working on a 1975 914. I just replaced a non working volt meter with a working period correct vdo volt meter. When the car is shut off the volt meter is reading the voltage.
Is this correct? Is the volt meter supposed to be switched on with the ignition or does it always show the voltage? I’m concerned that it will slowly drain the battery. The car has the stock wiring harness and originally came with a center gauge package. |
GregAmy |
Jul 27 2022, 06:51 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Crappy voltmeter is one of the reasons (space being the main driver) that I removed my console entirely. I got tired of seeing bad (and fluctuating) readings while driving around.
The final straw was when my big feet popped a fuse out without my knowing it and I thought I was stranded out in the middle of nowhere at night, trying to decide if I should chance the long drive through nowhere to get where I needed to be (clued in with no GEN light, I finally figured it out). For me, the idiot lights and the fuel/temp gauge combo work perfectly fine to tell me when it's time to park the car. |
emerygt350 |
Jul 27 2022, 07:34 AM
Advanced Member Group: Members Posts: 2,138 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Crappy voltmeter is one of the reasons (space being the main driver) that I removed my console entirely. I got tired of seeing bad (and fluctuating) readings while driving around. The final straw was when my big feet popped a fuse out without my knowing it and I thought I was stranded out in the middle of nowhere at night, trying to decide if I should chance the long drive through nowhere to get where I needed to be (clued in with no GEN light, I finally figured it out). For me, the idiot lights and the fuel/temp gauge combo work perfectly fine to tell me when it's time to park the car. I have actually found the volt meter (functioning as I have wired it) actually is a little helpful. Before I updated my regulator to solid state (and an optima battery that can take the voltage) I noticed that it dipped dangerously low with lights and wipers and heater all going. So low that I bet the battery discharge would have eventually caused the car to stop. If I were still running an old analog voltage regulator, I would want to know the details. Maybe the gen light would tell you about running a deficit but I suspect by the time it turns on from low battery charge, things might be too far. It's more of a "your alt belt just broke" kind of thing. Every once in a while I try to drive blind, but eventually I just want to know what's going on and put the 'super console' back in (on both of my fun cars). I think I approach this more like a pilot. They have no problem with tons of gauges letting them know what is up, and what may likely cause them to come down. |
Lo-Fi Version | Time is now: 6th June 2024 - 11:43 PM |
