| doobie123 |
Aug 5 2022, 04:59 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
| porschetub |
Aug 5 2022, 07:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,182 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
hi all, just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks So your ignition switch sounds fine,just make sure the rear lower plug is fully on to the column terminals ,mine wasn't and I lost most functions . Questions are ; Are all your battery red terminals nice and new in good connection, is the earth cable from battery to body good, whats the wiring on the starter like, battery good ? ,should be atleast 12.7V sitting, is the connection for seatbelt bypass a good one, did it run previously by bumping the starter, have you checked all body to ground connections by relayboard , others on here will ask further. All these things in good condition should solve your issues if sorted go on to Markhenrys guide to fit Ford solenoid as it works a treat and cheap ...did mine for pocket change. |
doobie123 ignition switch Aug 5 2022, 04:59 PM
nditiz1 The bypass is fine. Steering wheel off is fine.
... Aug 5 2022, 05:20 PM
doobie123
... Aug 5 2022, 05:31 PM
doobie123 something i didn't say was that there are 4 wi... Aug 5 2022, 05:34 PM
nditiz1 Any ford relay will work, 1970 ford galaxy, usuall... Aug 5 2022, 07:33 PM
doobie123 ok, here is an update on the ignition.
what i f... Aug 6 2022, 01:11 PM
nditiz1 I'm not seeing your grey wires with the plug. ... Aug 6 2022, 01:22 PM
dr914@autoatlanta.com bosch makes their wr1 hot start relay to install i... Aug 6 2022, 01:27 PM
doobie123 yes the 2 wires with the bullet connectors are wha... Aug 6 2022, 01:58 PM
nditiz1 The grey red making it work is just a coincidence.... Aug 6 2022, 03:05 PM
doobie123 ok, thanks i'll give it a try and keep ya post... Aug 6 2022, 04:06 PM
doobie123 just another question.
i thought there was a wire ... Aug 6 2022, 04:17 PM
nditiz1 That wire is the one that goes under your seat. I... Aug 6 2022, 08:04 PM
doobie123 ok great, thanks Aug 7 2022, 12:46 PM
doobie123 ok guys here is a bit of an up date. i cleaned the... Aug 7 2022, 05:03 PM
Superhawk996
should i just run a new wire from the solenoid to... Aug 7 2022, 05:24 PM
Superhawk996 Something is mis-wired in your car.
I suspect t... Aug 7 2022, 05:22 PM
doobie123 ok hope all you guys are still out there and are s... Aug 18 2022, 06:48 PM
emerygt350 I would start with just installing the hot start k... Aug 18 2022, 07:07 PM
doobie123 thanks emerygt. i gotsa ta know. should i have co... Aug 18 2022, 07:44 PM
nditiz1 I would not add anything new until you resolve the... Aug 18 2022, 07:52 PM
emerygt350 Since you have the hot starter kit, put it in.
Se... Aug 19 2022, 12:11 PM
doobie123 ok so i installed the hot start kit and...nothing ... Aug 19 2022, 01:56 PM
nditiz1 Your switch could be bad. Over time this is what ... Aug 19 2022, 02:32 PM
emerygt350 I believe he put a new switch in already. I would... Aug 19 2022, 03:55 PM
doobie123 yes, the switch is new both the plastic plug and t... Aug 19 2022, 04:13 PM
nditiz1 Sorry missed that about the new switch.
Ok so now... Aug 19 2022, 04:41 PM
doobie123 ok so heres further the switch was replaced to see... Aug 19 2022, 05:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th October 2026 - 10:02 AM |
