> ignition switch, no start
doobie123
post Aug 5 2022, 04:59 PM
hi all,
just received a new ignition switch from auto atlanta, those guys are great!
installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work.
could this effect it?
also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted.
i'm looking for any suggestions that i could try so please, any help would be great.
thanks
doobie123
post Aug 7 2022, 05:03 PM
ok guys here is a bit of an up date. i cleaned the trans ground and all the wires to the starter. the yellow has continuity from the starter to the under seat splice with the yellow/red stripe wire and the connection between the 2 are good.
at the starter, i have 14 V and with a load, 13.4 V.
after doing this i decided i'd try the two wires that should be going to the trans for... reverse lights? i jumped the grey/red stripe to the terminal on the solenoid which has the yellow wire attached and the key works. i removed it and no start, replaced it and the key works. these wires do go to the trans because i located the plug but when they are plugged in nothing changes.
the grey/red stripe wire has continuity with the pole on the ignition switch marked "S" the grey with a pole marked "P".
so what is the deal here? what else can i check or do? should i just run a new wire from the solenoid to the ignition switch pole marked "S"? it seems like it would fix the issue but what is the problem causing this?
thanks again for your help. tomorrow i'm gonna order the ignition circuit pamphlet from auto atlanta but i'd sure like to find a schematic before that comes in the mil. its driving me crazy!
doobie123   ignition switch   Aug 5 2022, 04:59 PM
nditiz1   The bypass is fine. Steering wheel off is fine. ...   Aug 5 2022, 05:20 PM
doobie123   The bypass is fine. Steering wheel off is fine. ...   Aug 5 2022, 05:31 PM
doobie123   something i didn't say was that there are 4 wi...   Aug 5 2022, 05:34 PM
porschetub   hi all, just received a new ignition switch from ...   Aug 5 2022, 07:28 PM
nditiz1   Any ford relay will work, 1970 ford galaxy, usuall...   Aug 5 2022, 07:33 PM
doobie123   ok, here is an update on the ignition. what i f...   Aug 6 2022, 01:11 PM
nditiz1   I'm not seeing your grey wires with the plug. ...   Aug 6 2022, 01:22 PM
dr914@autoatlanta.com   bosch makes their wr1 hot start relay to install i...   Aug 6 2022, 01:27 PM
doobie123   yes the 2 wires with the bullet connectors are wha...   Aug 6 2022, 01:58 PM
nditiz1   The grey red making it work is just a coincidence....   Aug 6 2022, 03:05 PM
doobie123   ok, thanks i'll give it a try and keep ya post...   Aug 6 2022, 04:06 PM
doobie123   just another question. i thought there was a wire ...   Aug 6 2022, 04:17 PM
nditiz1   That wire is the one that goes under your seat. I...   Aug 6 2022, 08:04 PM
doobie123   ok great, thanks   Aug 7 2022, 12:46 PM
doobie123   ok guys here is a bit of an up date. i cleaned the...   Aug 7 2022, 05:03 PM
Superhawk996   should i just run a new wire from the solenoid to...   Aug 7 2022, 05:24 PM
Superhawk996   Something is mis-wired in your car. I suspect t...   Aug 7 2022, 05:22 PM
doobie123   ok hope all you guys are still out there and are s...   Aug 18 2022, 06:48 PM
emerygt350   I would start with just installing the hot start k...   Aug 18 2022, 07:07 PM
doobie123   thanks emerygt. i gotsa ta know. should i have co...   Aug 18 2022, 07:44 PM
nditiz1   I would not add anything new until you resolve the...   Aug 18 2022, 07:52 PM
emerygt350   Since you have the hot starter kit, put it in. Se...   Aug 19 2022, 12:11 PM
doobie123   ok so i installed the hot start kit and...nothing ...   Aug 19 2022, 01:56 PM
nditiz1   Your switch could be bad. Over time this is what ...   Aug 19 2022, 02:32 PM
emerygt350   I believe he put a new switch in already. I would...   Aug 19 2022, 03:55 PM
doobie123   yes, the switch is new both the plastic plug and t...   Aug 19 2022, 04:13 PM
nditiz1   Sorry missed that about the new switch. Ok so now...   Aug 19 2022, 04:41 PM
doobie123   ok so heres further the switch was replaced to see...   Aug 19 2022, 05:46 PM
- Lo-Fi Version Time is now: 6th October 2026 - 10:00 AM
