| bbrock |
Aug 7 2022, 11:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
When I was reassembling my bare metal restoration, I probably spent close to 80 hours installing and adjusting body seals and gaskets. I wanted to get the car as air tight as possible to control cabin noise and leaks. I'm happy to say that my car seals tight enough to feel that pressure bubble when you close a door with top on and windows up like you get with a new modern car.
However, my one trouble spot was the top of the side triangle window. The 914Rubber main front targa seal is nice, but the rubber on mine was just a little too stiff to let the triangle frame to bed in for a proper seal. No amount of adjustment to move the frame forward helped. I even tried wrapping a ratchet strap around the top of the triangle window and windshield frame to pull the frame into the rubber and left it for two weeks to see if it would take a set. It didn't. There was this gap that let water trip in and created significant wind noise in an otherwise suprisingly quiet top on, windows up, cabin. ![]() Here is how I fixed it. 1. Clean the main targa seal, triangle window end cap, and top edge of the triangle window thoroughly with isopropyl alcohol. 2. Smear the triangle window end cap and a few inches of the top edge of the window with a generous, but smooth coat of petroleum jelly. This will act as a release agent for the silicone caulk you are about to apply. 3. Apply a thick bead of black silicone on the targa seal in the area where the gap needs to be filled. Don't worry about getting it smooth at this point. Don't overdo it or you will have more mess to clean up in the next step. 4. Close the door tight and use a lint free cloth soaked with isopropyl alcohol to clean up any silicone that oozes out on the inside. Be thorough with the clean up on this side. 5. Use your finger on the outside to force the silicone into the gap and smooth it out. I had to squirt in a bit more silicone to make sure it was completely filled. 6. When you are satisfied the gap is completely filled with silicone and it looks nice and smooth, carefully go over inside and out with a clean alcohol soaked cloth to tidy up any stray silicone. Much easier at this stage than after silicone has cured. Careful not wipe the petroleum jelly off the end cap though. 7. Leave the car alone for at least 12 hours to let the silicone cure. After the silicone has cured, open the door and clean off the petroleum jelly with alcohol. ![]() You should have a perfect seal and nearly invisible repair. This picture was taken with a flash to better show the cured silicone. And here is without flash which is more representative of how it looks in natural light. The small amount of jagged slag is only noticeable if you are looking for it, and disappears when the door is closed, but I'll let the silicone cure a few more days and try to smooth it with some fine sandpaper. Happy drip and whistle free motoring! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif) |
| friethmiller |
Aug 8 2022, 07:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,592 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Man! This is one issue I have on both doors. I spent countless hours trying to get the top of the triangle glass to set properly in the Targa seal. I thought this was on me. I felt like I had screwed it up somehow. I personally think the bottom part of the triangle window seal is too thick and prevents the full adjustment but I'm not sure.
| Superhawk996 |
Aug 8 2022, 08:02 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,149 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I personally think the bottom part of the triangle window seal is too thick and prevents the full adjustment but I'm not sure. I've wondered if a little deeper channel in the bottom of the triangle seal would allow the whole triangle window assembly to sit low enough for the corner to nestle tightly into the targa seal and still have everything else line up. I wasn't about to start carving on the seal to find out though. If you bought the 914Rubber window triangle seals, they are indeed too thick in several places. Again, I'm not trying to beat down 914Rubber -- I'm happy to have access to the triangle seals that would otherwise be NLA. I was able to rework the part which is better than having no part at all. But like the targa seal, would pay more for a part that simply fit exactly like OEM and didn't need rework. I ended up only using the driver side. The passenger side OEM part was still in decent shape. After the amount of rework I had to do with the driver side triangle seal, I decided to pass on doing the passenger side for now. I ended up having to carve down the bottom V-ribs on the bottom to allow the seal to sit deep enough in the door sheet metal pocket. ![]() OEM (top) vs. 914Rubber (bottom) - picture doesn't quite do it justice. V ribs were a little taller, and seemed to be less compressible. Some of that could simply be that OEM seal was installed for so long that it had taken a set. However, that "set" is where the triangle needed to be to have a chance of mating with the targa seal. ![]() I used carbide in a Dremmel to deepen the pocket that the triangle glass sits in to get the triangle back down to the same position as the OEM seal allowed. My part is off a 73' and has a pocket to fit the metal blade that bolts to the window channel that helps hold the window triangle glass. In PM's with 914Rubber, it sounds like that pocket was eliminated in later 75' & 76'. So to use with 73' window channel, I also had to carve out the square pocket. I think the alternative was to remove the metal blade from my window channel. I opted not to do that since I think that blades helps stabilize and retain the triangle glass. Personally, I've only owned 73's so I don't know how well later cars fit without the pocket and/or the channel bracket my car has. |
| SirAndy |
Aug 8 2022, 09:08 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,550 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My part is off a 73' and has a pocket to fit the metal blade that bolts to the window channel that helps hold the window triangle glass. In PM's with 914Rubber, it sounds like that pocket was eliminated in later 75' & 76'. So to use with 73' window channel, I also had to carve out the square pocket. I think the alternative was to remove the metal blade from my window channel. I opted not to do that since I think that blades helps stabilize and retain the triangle glass. Personally, I've only owned 73's so I don't know how well later cars fit without the pocket and/or the channel bracket my car has. I didn't know later cars omitted that metal tab. (IMG:style_emoticons/default/idea.gif) |
bbrock How To: Close the Gap on Triangle Window Seal Aug 7 2022, 11:39 AM
FlacaProductions Your ingenuity never fails to impress. Practical ... Aug 7 2022, 12:52 PM
Dion Nice one Brent! I may need to do this. Evil ge... Aug 7 2022, 01:37 PM
Superhawk996 Good job on a fix. :trophy:
Would be far nicer ... Aug 7 2022, 02:18 PM
mb911
Would be far nicer... Aug 7 2022, 02:46 PM
Superhawk996
My little story just was to express how surprise... Aug 7 2022, 03:43 PM
Olympic 914 I have used a product called Shoe Goo. On things o... Aug 7 2022, 03:36 PM
StarBear
I have used a product called Shoe Goo. On things ... Aug 7 2022, 05:47 PM
bbrock
I have used a product called Shoe Goo. On things... Aug 7 2022, 06:11 PM
vitamin914
I have used a product called Shoe Goo. On things ... Aug 8 2022, 02:40 PM
SirAndy I'm pretty sure you can adjust the angle of th... Aug 7 2022, 03:49 PM
bbrock
I'm pretty sure you can adjust the angle of t... Aug 7 2022, 03:54 PM
mb911
I'm pretty sure you can adjust the angle of ... Aug 7 2022, 05:29 PM
Superhawk996
[quote name='bbrock' post='3021064' date='Aug 7 2... Aug 7 2022, 05:34 PM
bbrock
[quote name='bbrock' post='3021064' date='Aug 7 ... Aug 7 2022, 06:06 PM
bbrock
I used carbide in a Dremmel to deepen the pocket ... Aug 8 2022, 10:42 AM
Mikey914 SO, to comment on the production of these seals. 1... Aug 8 2022, 11:03 AM
bbrock @Mikey914
Thanks for this Mark. As others have ... Aug 8 2022, 11:11 AM
Superhawk996
@[url=http://www.914world.com/bbs2/index.php?show... Aug 8 2022, 11:56 AM
Mikey914 Thanks,
Yes this winds up being about more than ma... Aug 8 2022, 11:18 AM
StarBear
Thanks,
Yes this winds up being about more than m... Aug 8 2022, 03:24 PM
Mikey914 We were "lucky" that there was a grant, ... Aug 9 2022, 01:06 AM
bkrantz I used Porsche factory (recent production) triangl... Aug 9 2022, 08:38 PM
worn
I used Porsche factory (recent production) triang... Aug 10 2022, 03:00 AM
bbrock I drove 100 miles from Butte to home @ 80mph with ... Aug 10 2022, 07:14 AM
Mikey914 I keep looking at this and something doesn't l... Aug 10 2022, 04:37 PM
Superhawk996
Given that the blocks are identical to the factor... Aug 11 2022, 06:30 AM
Superhawk996
There appears to be a 1/2" section of rubbe... Aug 11 2022, 07:14 AM
bbrock I think going a little softer on the vertical seal... Aug 10 2022, 06:52 PM
mb911
I think going a little softer on the vertical sea... Aug 10 2022, 07:49 PM
mepstein No surprise when this came up for sale, i jumped o... Aug 11 2022, 07:15 AM
Superhawk996
No surprise when this came up for sale, i jumped ... Aug 11 2022, 07:38 AM
Mikey914 Ok,
Lets have a conversation on the process.
#1- ... Aug 11 2022, 03:13 PM
GeorgeKopf Wow. I am so glad that I found this thread. I sp... Oct 24 2026, 12:25 PM
Superhawk996 George
Look inside the targa seal at the bottom ... Oct 24 2026, 12:59 PM
burton73 A little history. Back in 2007 or so you could not... Oct 24 2026, 03:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 07:30 PM |
