| bbrock |
Aug 7 2022, 11:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
When I was reassembling my bare metal restoration, I probably spent close to 80 hours installing and adjusting body seals and gaskets. I wanted to get the car as air tight as possible to control cabin noise and leaks. I'm happy to say that my car seals tight enough to feel that pressure bubble when you close a door with top on and windows up like you get with a new modern car.
However, my one trouble spot was the top of the side triangle window. The 914Rubber main front targa seal is nice, but the rubber on mine was just a little too stiff to let the triangle frame to bed in for a proper seal. No amount of adjustment to move the frame forward helped. I even tried wrapping a ratchet strap around the top of the triangle window and windshield frame to pull the frame into the rubber and left it for two weeks to see if it would take a set. It didn't. There was this gap that let water trip in and created significant wind noise in an otherwise suprisingly quiet top on, windows up, cabin. ![]() Here is how I fixed it. 1. Clean the main targa seal, triangle window end cap, and top edge of the triangle window thoroughly with isopropyl alcohol. 2. Smear the triangle window end cap and a few inches of the top edge of the window with a generous, but smooth coat of petroleum jelly. This will act as a release agent for the silicone caulk you are about to apply. 3. Apply a thick bead of black silicone on the targa seal in the area where the gap needs to be filled. Don't worry about getting it smooth at this point. Don't overdo it or you will have more mess to clean up in the next step. 4. Close the door tight and use a lint free cloth soaked with isopropyl alcohol to clean up any silicone that oozes out on the inside. Be thorough with the clean up on this side. 5. Use your finger on the outside to force the silicone into the gap and smooth it out. I had to squirt in a bit more silicone to make sure it was completely filled. 6. When you are satisfied the gap is completely filled with silicone and it looks nice and smooth, carefully go over inside and out with a clean alcohol soaked cloth to tidy up any stray silicone. Much easier at this stage than after silicone has cured. Careful not wipe the petroleum jelly off the end cap though. 7. Leave the car alone for at least 12 hours to let the silicone cure. After the silicone has cured, open the door and clean off the petroleum jelly with alcohol. ![]() You should have a perfect seal and nearly invisible repair. This picture was taken with a flash to better show the cured silicone. And here is without flash which is more representative of how it looks in natural light. The small amount of jagged slag is only noticeable if you are looking for it, and disappears when the door is closed, but I'll let the silicone cure a few more days and try to smooth it with some fine sandpaper. Happy drip and whistle free motoring! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif) |
| mepstein |
Aug 11 2022, 07:15 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,952 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
No surprise when this came up for sale, i jumped on it.
http://www.914world.com/bbs2/index.php?sho...p;hl=targa+seal Attached image(s)
bbrock How To: Close the Gap on Triangle Window Seal Aug 7 2022, 11:39 AM
FlacaProductions Your ingenuity never fails to impress. Practical ... Aug 7 2022, 12:52 PM
Dion Nice one Brent! I may need to do this. Evil ge... Aug 7 2022, 01:37 PM
Superhawk996 Good job on a fix. :trophy:
Would be far nicer ... Aug 7 2022, 02:18 PM
mb911
Would be far nicer... Aug 7 2022, 02:46 PM
Superhawk996
My little story just was to express how surprise... Aug 7 2022, 03:43 PM
Olympic 914 I have used a product called Shoe Goo. On things o... Aug 7 2022, 03:36 PM
StarBear
I have used a product called Shoe Goo. On things ... Aug 7 2022, 05:47 PM
bbrock
I have used a product called Shoe Goo. On things... Aug 7 2022, 06:11 PM
vitamin914
I have used a product called Shoe Goo. On things ... Aug 8 2022, 02:40 PM
SirAndy I'm pretty sure you can adjust the angle of th... Aug 7 2022, 03:49 PM
bbrock
I'm pretty sure you can adjust the angle of t... Aug 7 2022, 03:54 PM
mb911
I'm pretty sure you can adjust the angle of ... Aug 7 2022, 05:29 PM
Superhawk996
[quote name='bbrock' post='3021064' date='Aug 7 2... Aug 7 2022, 05:34 PM
bbrock
[quote name='bbrock' post='3021064' date='Aug 7 ... Aug 7 2022, 06:06 PM
friethmiller Man! This is one issue I have on both doors. ... Aug 8 2022, 07:33 AM
Superhawk996
I personally think the bottom part of the triangl... Aug 8 2022, 08:02 AM
SirAndy My part is off a 73' and has a pocket to fit t... Aug 8 2022, 09:08 AM
bbrock
I used carbide in a Dremmel to deepen the pocket ... Aug 8 2022, 10:42 AM
Mikey914 SO, to comment on the production of these seals. 1... Aug 8 2022, 11:03 AM
bbrock @Mikey914
Thanks for this Mark. As others have ... Aug 8 2022, 11:11 AM
Superhawk996
@[url=http://www.914world.com/bbs2/index.php?show... Aug 8 2022, 11:56 AM
Mikey914 Thanks,
Yes this winds up being about more than ma... Aug 8 2022, 11:18 AM
StarBear
Thanks,
Yes this winds up being about more than m... Aug 8 2022, 03:24 PM
Mikey914 We were "lucky" that there was a grant, ... Aug 9 2022, 01:06 AM
bkrantz I used Porsche factory (recent production) triangl... Aug 9 2022, 08:38 PM
worn
I used Porsche factory (recent production) triang... Aug 10 2022, 03:00 AM
bbrock I drove 100 miles from Butte to home @ 80mph with ... Aug 10 2022, 07:14 AM
Mikey914 I keep looking at this and something doesn't l... Aug 10 2022, 04:37 PM
Superhawk996
Given that the blocks are identical to the factor... Aug 11 2022, 06:30 AM
Superhawk996
There appears to be a 1/2" section of rubbe... Aug 11 2022, 07:14 AM
bbrock I think going a little softer on the vertical seal... Aug 10 2022, 06:52 PM
mb911
I think going a little softer on the vertical sea... Aug 10 2022, 07:49 PM
Superhawk996
No surprise when this came up for sale, i jumped ... Aug 11 2022, 07:38 AM
Mikey914 Ok,
Lets have a conversation on the process.
#1- ... Aug 11 2022, 03:13 PM
GeorgeKopf Wow. I am so glad that I found this thread. I sp... Oct 24 2026, 12:25 PM
Superhawk996 George
Look inside the targa seal at the bottom ... Oct 24 2026, 12:59 PM
burton73 A little history. Back in 2007 or so you could not... Oct 24 2026, 03:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 07:29 PM |
