| yeahmag |
Aug 10 2022, 12:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,483 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I have 66mm studs on the car, but have too much stick out (15mm). Anybody sitting on 10 (just doing the rear) studs in the 50-55mm range?
(IMG:style_emoticons/default/beerchug.gif) |
| Montreal914 |
Aug 11 2022, 09:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,135 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Curious; (IMG:style_emoticons/default/idea.gif)
You will need to remove the hubs to press these out? Can this be done without damaging the bearing? |
| Olympic 914 |
Aug 12 2022, 06:18 AM
![]() ![]() ![]() Group: Members Posts: 1,783 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Curious; (IMG:style_emoticons/default/idea.gif) You will need to remove the hubs to press these out? Can this be done without damaging the bearing? Removed the rear studs using a HF ball joint tool. Didn't have to remove the hub. |
| bdstone914 |
Aug 12 2022, 07:00 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,322 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Curious; (IMG:style_emoticons/default/idea.gif) You will need to remove the hubs to press these out? Can this be done without damaging the bearing? Removed the rear studs using a HF ball joint tool. Didn't have to remove the hub. I know the shorter studs can be removed with the hub installed but there may be a clearance to remove the longer studs as they will hit the trailing arm. |
yeahmag WTB 50-55mm wheel studs Aug 10 2022, 12:03 PM
914Sixer Check around. Studs are M14 x 1.5. Should be som... Aug 11 2022, 07:50 AM
Literati914 Aaron, I think I may have some in a set of 911 fro... Aug 11 2022, 09:34 AM
yeahmag Bump! Still hoping to find some shorter (used)... Aug 16 2022, 02:37 PM
gms here is the tool i made to remove studs from the ... Aug 17 2022, 08:56 AM
brant Last fall I was looking for 50/55 studs
looked eve... Aug 17 2022, 02:54 PM
yeahmag Think this may work...
https://www.ecstuning.com/... Aug 17 2022, 06:03 PM
acar24
I have 66mm studs on the car, but have too much s... Sep 4 2022, 07:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 06:37 AM |
