> Door hinges, Original door hinges… Painted?
Ishley
post Aug 2 2022, 09:20 PM
I have a 1972 1.7 that I’m restoring. One of the areas that I can’t find any information on is how the door hinges were originally finished. Mine have been sprayed over several times and when I repaint I want it to look right.
Were the hinges painted to the same color of the car? What about the bolts and pins. We’re they painted or zinc/cadmium plated. I ran my bolts through my ultrasonic cleaner and it appears they are black underneath the layers of paint.
Does anyone have an original picture of how it was finished from the factory?
wonkipop
post Aug 12 2022, 11:52 PM
came across old ad for a 1970 914.
most of the paint looks original.
certainly all inners.
only one image is a clear shot of the hinges.
looks like the hinge pin could be painted in this early car.
hard to discern but think its white paint there not bare metal hinge pin.
@SirAndy
might be good to shift this thread over to originality section of site?
nathanxnathan
post Aug 13 2022, 12:50 AM
QUOTE(wonkipop @ Aug 12 2022, 10:52 PM) *
Opening the image in a new tab on the site will show it unscaled, but it's still indiscernible.
I would say it looks unpainted if I had to guess.
It's interesting that car's vin is 11,000 cars after mine, a fairly late 70, but the chassis number is 15 weeks before mine. It has the later driver seat tilt adjustment arm and the 2 section center tray.
wonkipop
post Aug 13 2022, 01:37 AM
QUOTE(nathanxnathan @ Aug 13 2022, 12:50 AM) *
even in 74 the karmann numbers wander around off kilter with the vin numbers.
however that does not sound quite right that there is such a discrepancy.
you must have a very very early 69 car @nathanxnathan . it must be within the first thousand cars built and it must have been started 15 weeks before august 69. which is interesting.
the one i found above is an august 70 car. right towards end of 70 MY production.
nathanxnathan
post Aug 13 2022, 09:29 AM
QUOTE(wonkipop @ Aug 13 2022, 12:37 AM) *
@wonkipop My car, the vin and chassis number are pretty close, both in November of 69.
Chassis #4839528 I work out to being the 28th car built on Wednesday Nov 25, 1969
The vin is 4702900987
I don't have a door sticker — it was removed during a respray I assume. The production numbers listed here on 914world go by actual year, saying 1543 4 cylinder cars were produced in 69, so my vin agrees with that, if it was #987. I think the production numbers here are based on vins, not chassis numbers?
The white car, I can't make out the production date on the door sticker, but with
vin 4702912026 that would make it the 12,026 — 11,000 cars later — pretty far on into 1970 for a completion date if there were about 22,000 1970 model year 4 cylinder cars.
The white car's chassis number is 3319577 which I think is August 11th, 1969. So it sat as a chassis for 10 months or so?
It seems like the chassis would have got painted, like they couldn't have left it around in bare metal that whole time. The Karmann badge is applied after paint so that seems logical that they create and mark the chassis with the number. Then the vin gets assigned once the whole car is assembled. I guess chassis numbers are what would be relevant here, rather than vins as it's a chassis question.
wonkipop
post Aug 13 2022, 03:30 PM
QUOTE(nathanxnathan @ Aug 13 2022, 09:29 AM) *
i doubt very much the K number on the white car goes to august 69 and that it sat for 10 months. i would say its a late production car and the K number is indicating august 70.
unfortunately no vin sticker was available in the dealer photos to show that.
the numbers on 1970 MY cars are not 22,000. thats the production for the calendar year 1970. production was only around 13,000 for the 4s for MY 70. since its vin is up in the 12,000 range its about a 1000 from the end of 70 model. they built about 100 cars a day on average through most of the production run. so its a car 2 weeks from the end of 70 MY. k number makes it an early aug 1970 car. which is right. they usually took several weeks off sometime in or around august as a summer holiday and shut the factory down or slowed production down between the model year breaks.
the chassis number checks out. there is nothing odd about it.
nathanxnathan
post Aug 13 2022, 10:17 PM
QUOTE(wonkipop @ Aug 13 2022, 02:30 PM) *
That makes sense about the 22,000 — I was adding 69 production to the total 70 production and forgot for a second that 4 months of 70 production are 71 model year cars.
But about when the white car was made does seem strange to me. Everything I've read says August 1st started the production year. The 33rd week of the year, whether 69 or 70 was the week starting Monday August 11th or 10th respectively. If the chassis was made August 10th, 1970 it would be a 1971 model year car, but it's clearly not. And that's just the chassis — the car would have been completed even later. So it is weird to me that either the car was made in 69 and the chassis sat for 10+ months or else they didn't start making 71 model year cars until halfway through August. And that's not even thinking about the break — I thought that happened July..
Ishley   Door hinges   Aug 2 2022, 09:20 PM
wonkipop   74 1.8 orig paint think its same all years.   Aug 2 2022, 10:55 PM
sechszylinder   I have a 1972 1.7 that I’m restoring. One of th...   Aug 3 2022, 01:43 AM
StarBear   Here are mine. Original and unmolested to my best ...   Aug 3 2022, 05:53 AM
wonkipop   Here are mine. Original and unmolested to my best...   Aug 3 2022, 06:48 AM
mepstein   I’ve only seen painted.   Aug 3 2022, 06:18 AM
StarBear   I’ve only seen painted. Probably mine have bee...   Aug 3 2022, 06:39 AM
mepstein   I’ve only seen painted. Probably mine have be...   Aug 3 2022, 06:47 AM
StarBear   Oh, I may have changed them out many decades ago. ...   Aug 3 2022, 06:54 AM
mepstein   This is from the 27k mile car on bat. I’m not sa...   Aug 3 2022, 06:56 AM
wonkipop   here is my karmann tag proper in focus. she is no ...   Aug 3 2022, 07:08 AM
StarBear   And remember - Hans seems to have worked on buildi...   Aug 3 2022, 07:15 AM
9146GUY   My original 914-6 unmolested.   Aug 3 2022, 07:52 AM
wonkipop   My original 914-6 unmolested. wow whats thet...   Aug 3 2022, 08:02 AM
brant   I’m pretty sure they were all originally painted...   Aug 3 2022, 08:02 AM
mepstein   Looks like a Ziebart plug.   Aug 3 2022, 08:05 AM
wonkipop   Looks like a Ziebart plug. :beer2: of course...   Aug 3 2022, 08:18 AM
Ishley   Thanks everyone One thing that I can’t understa...   Aug 3 2022, 08:39 AM
nathanxnathan   Thanks everyone One thing that I can’t underst...   Aug 3 2022, 08:50 AM
mepstein   Production facilities have a lot of tools and tech...   Aug 3 2022, 09:02 AM
fixer34   I'll add to the mysteries... Factory -6, I...   Aug 3 2022, 11:36 AM
mepstein   I'll add to the mysteries... Factory -6, I...   Aug 3 2022, 02:36 PM
SirAndy   Always only seen fully painted on original cars .....   Aug 3 2022, 01:00 PM
wonkipop   Always only seen fully painted on original cars ....   Aug 3 2022, 04:19 PM
SirAndy   or......early cars (4s and 6s) got painted pins? ...   Aug 4 2022, 09:24 AM
wonkipop   couple more 74s from research file.   Aug 3 2022, 04:37 PM
StarBear   I’m convinced by the data and pics provided. Min...   Aug 3 2022, 04:47 PM
SKL1   Don't have a picture handy but I've had my...   Aug 3 2022, 08:19 PM
bbrock   I know this is a bit of apples and oranges being a...   Aug 4 2022, 01:08 PM
wonkipop   I know this is a bit of apples and oranges being ...   Aug 4 2022, 04:18 PM
StarBear   Wonder what a comparison to other Karmann cars (Ga...   Aug 4 2022, 01:23 PM
wonkipop   Wonder what a comparison to other Karmann cars (G...   Aug 6 2022, 01:47 AM
nathanxnathan   The car I've been working on is pretty early, ...   Aug 4 2022, 02:14 PM
mepstein   Some of the very early cars are quite different fr...   Aug 4 2022, 02:56 PM
nathanxnathan   Some of the very early cars are quite different f...   Aug 4 2022, 03:09 PM
wonkipop   Some of the very early cars are quite different ...   Aug 4 2022, 04:26 PM
nathanxnathan   if they were when is the cut off? original poster...   Aug 4 2022, 05:33 PM
wonkipop   i had a high speed cruise through BAT on 912s. ha...   Aug 4 2022, 05:06 PM
wonkipop   another 74 from the 1.8 engine research. 44K mile ...   Aug 4 2022, 05:08 PM
wonkipop   here is a 72 just up on BAT. inners all looked to ...   Aug 5 2022, 05:24 PM
wonkipop   had a good look in 912 section of BAT. managed to ...   Aug 5 2022, 11:52 PM
wonkipop   came across old ad for a 1970 914. most of the pa...   Aug 12 2022, 11:52 PM
nathanxnathan   came across old ad for a 1970 914. most of the p...   Aug 13 2022, 12:50 AM
wonkipop   came across old ad for a 1970 914. most of the ...   Aug 13 2022, 01:37 AM
nathanxnathan   even in 74 the karmann numbers wander around off ...   Aug 13 2022, 09:29 AM
wonkipop   [quote name='wonkipop' post='3022236' date='Aug 1...   Aug 13 2022, 03:30 PM
nathanxnathan   i doubt very much the K number on the white car g...   Aug 13 2022, 10:17 PM
wonkipop   i doubt very much the K number on the white car ...   Aug 14 2022, 01:39 AM
dr914@autoatlanta.com   16,000 mile original 914-6   Aug 13 2022, 09:47 AM
wonkipop   16,000 mile original 914-6 what MY is that 914...   Aug 13 2022, 03:32 PM
StarBear   Took the time/effort to clean, prime, and paint my...   Aug 13 2022, 10:00 AM
wonkipop   Took the time/effort to clean, prime, and paint m...   Aug 13 2022, 04:02 PM
BENBRO02   I’m thinking the factory aligned the doors befor...   Aug 13 2022, 02:54 PM
wonkipop   @nathanxnathan i think i found the answer to the...   Aug 14 2022, 06:23 AM
nathanxnathan   @[url=http://www.914world.com/bbs2/index.php?show...   Aug 14 2022, 02:39 PM
wonkipop   [quote name='wonkipop' post='3022440' date='Aug 1...   Aug 14 2022, 05:19 PM
wonkipop   @nathanxnathan i had a look at 73 to 74. last 7...   Aug 14 2022, 06:16 PM
StarBear   Yep, my 74 produced in Nov 74 but lag until I got ...   Aug 14 2022, 03:58 PM
wonkipop   Yep, my 74 produced in Nov 74 but lag until I got...   Aug 14 2022, 05:22 PM
nathanxnathan   @wonkipop Impressive research :beer2: So most ...   Aug 14 2022, 11:33 PM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 14 2022, 11:53 PM
- Lo-Fi Version Time is now: 22nd November 2026 - 09:07 AM
