> Bringing it back:, Improved Original for 4742910780
Van B
post Aug 16 2022, 05:51 PM
Evening 914 World!
I’ve been gathering parts over the past few months and have finally reached critical mass. So, let the project thread begin!
After working on the FI through the winter, I’m satisfied that the engine remains in good health with it’s original 53k miles. However, the rubber and plastic holding everything together is a different story.
Which brings me to the scope and objective of this project. In short, I am looking for what I will call, “Improved Original”. What the phrase means to me is that I want to maintain the character and feel of the original car, but still take advantage of any and all modern improvements that will either, improve reliability, safety, operability, or any combination there of. This will include a suspension and chassis rebuild, power train reseal and refinishing, brake system rebuild, and fuel system overhaul.
When I’m done, I want to have a car that drives like it’s nearly new, but doesn’t look over restored. Because the car is a survivor, I think it’s important to keep the stories and history of the car intact.
Finally, I’d like to post my thanks to the community and vendors that make it possible to enjoy this hobby. Stay tuned!
Van
bbrock
post Aug 16 2022, 07:43 PM
I will watching this for sure! (IMG:style_emoticons/default/popcorn[1].gif) This is very much the philosophy I've followed on my build which is still a work in progress. Some thoughts from my own journey down this path:
For the most part, I decided to restore the car to like new condition because it was so well engineered to begin with. Suspension and brakes remain stock but I did upgrade to Bilstein shocks and turbo tie rods. The engine (2.0L) was rebuilt to european stock specs so displacement remained stock but compression raised. The exception was an unfortunate decision in the late 1980s when bottom end of the engine was rebuilt to install a carb cam. A mild one, but not a decision I'd make today. As a result, the car is currently carbed but I'll return to that later. Other than the carbs, I don't regret any of this. I've taken several 300+ mile trips this summer and the car as Porsche designed performs and handles fantastic. It is just a wonderfully balanced package and I have not wished for more or less of anything.
Now for the mods. First, my rule on mods is they should be as stealth as possible. Invisible is even better. Visible mods should look as if they came from the factory down to the wiring. Mods also need to be non-destructive so no drilling allowed. I want them to be easily reversible in case someone wants to go purist some day. With that philosophy, here are mods I did or plan to do in order of priority.
Safety First - I wanted to leave no compromise here within reasonable limits. Nothing crazy like adding airbags or anything, but there were a number of mods.
  • LED lights. This was LED lights all around. Headlights, of course, but also all indicator, tail, and brake lamps to brighten them.
  • Porterfield brake pads. No compromise when it comes to stopping.
  • Enhanced visibility. I added a third brake light which is a must have on a car that sits this low, and stealth side markers to compensate for deleting the ugly warts to bring the car to Euro spec. Actually, there was a practical reason for deleting the markers, but that's not important. The lights I chose are ultra low profile LED strips most commonly used on motorcyles. They are so low profile nobody notices they are there until turned on and they do enhance visibility substantially. I violated the non-destructive rule with the side marker delete, but I did make a paper template to allow drilling the holes exactly where they were if some future owner has a wart fetish.
Reliability - Like you, this is important and is an ongoing project. I think there is potential for substantial gains in reliability and longevity by modernizing the ignition and fuel systems on these cars. At the top of my list was ditching the points and condensor. Right now I'm running a Pertronix which is nice, but I have higher goals. Here is where I'm hopefully headed this winter.
  • Ditch the carbs and go Megasquirt. I can run this with the carb cam and also add a lot of modern fuel management features like sequential injection, real time barometric correction, closed loop fuel mixture adjustment, etc. I'll run this with the stock intake manifold and air cleaner with electronics hidden away in a stock ECU box.
  • Upgrade ignition with full sequential coil on plug spark management. Full sequential is a bit over the top but I like a challenge and there are some gains to be had there for efficiency. It is also helpful for the next reliability upgrade.
  • Switch to iridium plugs. I love being able to get 50K-100K out of a set of modern plugs. IMO, the less time spent with my head in the engine bay where swear words are invented, the better.
  • Synthetic oil. I've read all the debates about synthetic oil in vintage and/or flat tappet engines. I'm convinced it will improve longevity and there are high zinc synthetic blends out there.
Creature comforts - There are some things you've just gotta have, but you don't have to be flashy about them. Here are mine:
[list]
[*]Tunes. I've gotta have decent tunes with bluetooth capabilities so I stuffed a modern Blaupunkt in the dash. I tried to install it in a very factory way so it doesn't draw attention to not being factory correct. Having a period correct radio converted to solid state is tempting, but a little too spendy for me, as is the new(ish) Porsche single DIN radio/navigation system. I've also hidden an amplifier in the center console and a subwoofer in the passenger kick space where the foam block goes. Still waiting on 914R to introduce their subwoofer box to complete the mod. Other than the radio itself, there is no visible hint of a non-stock system.
[*]Cup holder. It's a must have. I don't smoke, but I drink so I converted the ashtray into a pop-out cup holder. Total stealth when closed. Last week I was riding with a friend and popped out the cup holder while making a comment that people think Toyota invented the in-dash cup holder but my 50 year old car had one. He looked at me and asked, "is that stock?" That's the level of stealth I was going for so it made me happy.
[*]Charge ports. Let's face it, we need to be able to run and charge stuff these days. I built a little console that fits inside the center console that contains an extra 12v accessory plug, a USB-b plug, and a USB-c plug. I like to open the console and brag that 914s were so far advanced that they had USB outlets decades before USB was invented (IMG:style_emoticons/default/laugh.gif)
So that's were I've been and going with this "make it better without changing it" concept. I can't wait to see what you do! (IMG:style_emoticons/default/beerchug.gif)
Van B   Bringing it back:   Aug 16 2022, 05:51 PM
Van B   Day 1: removed the engine :beer2:   Aug 16 2022, 05:53 PM
StarBear   :popcorn: Anxious to follow your exploits, Van, p...   Aug 16 2022, 05:57 PM
emerygt350   Good luck van! Everytime I dig around in mine...   Aug 16 2022, 06:14 PM
Van B   Thanks guys! @StarBear most of those choice...   Aug 16 2022, 06:36 PM
StarBear   Thanks guys! [b]@[url=http://www.914world.c...   Aug 16 2022, 06:42 PM
Van B   These guys: https://www.fcpeuro.com/products/porsc...   Aug 16 2022, 07:15 PM
StarBear   These guys: https://www.fcpeuro.com/products/pors...   Aug 16 2022, 08:02 PM
Van B   [quote name='Van B' post='3022989' date='Aug 16 2...   Aug 16 2022, 08:10 PM
StarBear   [quote name='Van B' post='3022989' date='Aug 16 ...   Aug 17 2022, 10:42 AM
StarBear   [quote name='Van B' post='3023004' date='Aug 16 2...   Aug 17 2022, 02:22 PM
Van B   [quote name='Van B' post='3023004' date='Aug 16 ...   Aug 17 2022, 02:45 PM
StarBear   [quote name='StarBear' post='3023191' date='Aug 1...   Aug 17 2022, 03:45 PM
wonkipop   [quote name='Van B' post='3023004' date='Aug 16 ...   Aug 17 2022, 05:22 PM
wonkipop   Van; Rats. Looked under there and the center bolt...   Aug 17 2022, 10:16 PM
wonkipop   you and your car will enjoy those bilsteins i see ...   Aug 16 2022, 07:33 PM
Van B   you and your car will enjoy those bilsteins i see...   Aug 16 2022, 08:14 PM
bbrock   I will watching this for sure! :popcorn: Th...   Aug 16 2022, 07:43 PM
Van B   @[url=http://www.914world.com/bbs2/index.php?showu...   Aug 16 2022, 08:24 PM
bbrock   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 16 2022, 08:51 PM
Van B   You only need to loosen it enough to slip the moun...   Aug 17 2022, 04:34 PM
StarBear   You only need to loosen it enough to slip the mou...   Aug 17 2022, 05:30 PM
wonkipop   @Van B are you going to install sway bars?   Aug 17 2022, 05:30 PM
Van B   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 17 2022, 05:53 PM
wonkipop   @StarBear - you undo the 2 smaller M8 bolts on e...   Aug 17 2022, 05:42 PM
StarBear   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 17 2022, 07:53 PM
Van B   No worries @StarBear . You’re over thinking it....   Aug 17 2022, 05:59 PM
wonkipop   this might also give you pause to think @StarBear...   Aug 17 2022, 11:55 PM
StarBear   If it’s good enough for @wonkipop , it’s good...   Aug 18 2022, 05:42 AM
StarBear   Van; would these be the torques you mentioned? #2 ...   Aug 19 2022, 03:13 PM
Van B   Steve, for the life of me, I can’t find the M12 ...   Aug 19 2022, 05:09 PM
StarBear   :cheer: :Qarl: :beer2: Onward! Thanks and b...   Aug 19 2022, 05:35 PM
Van B   So the theme of today is: Better lucky than good a...   Aug 20 2022, 07:03 PM
Van B   Another lesson for folks: Don’t use spray adhesi...   Aug 20 2022, 07:09 PM
wonkipop   Another lesson for folks: Don’t use spray adhes...   Aug 20 2022, 07:20 PM
wonkipop   car gets better the deeper you go. :beer2:   Aug 20 2022, 07:10 PM
Van B   It’s original zeibart coating and it was sprayed...   Aug 20 2022, 07:28 PM
wonkipop   It’s original zeibart coating and it was spraye...   Aug 20 2022, 07:42 PM
Van B   Electrolysis for the win. Only had a couple hours...   Aug 21 2022, 06:37 PM
wonkipop   still a lucky man. have you taken the sill roc...   Aug 21 2022, 11:51 PM
Van B   Haven’t taken the rockers off yet, but I’m rea...   Aug 22 2022, 03:13 PM
Van B   Bottom line, for the engine bay, I have a few pinh...   Aug 22 2022, 03:15 PM
wonkipop   there is one place left after you look behind the ...   Aug 23 2022, 03:03 AM
Van B   You mean that little box section reinforcement dow...   Aug 23 2022, 11:18 AM
wonkipop   You mean that little box section reinforcement do...   Aug 23 2022, 04:38 PM
wonkipop   quick question for you @Van B while i think of i...   Aug 23 2022, 05:43 PM
Van B   Black on my car.   Aug 23 2022, 06:05 PM
wonkipop   Black on my car. thanks mate. :beer2: the c...   Aug 23 2022, 06:10 PM
Van B   My only gripe about the 74 1.8 is that emissions f...   Aug 23 2022, 06:45 PM
wonkipop   My only gripe about the 74 1.8 is that emissions ...   Aug 25 2022, 02:28 PM
StarBear   [quote name='Van B' post='3024442' date='Aug 23 2...   Aug 25 2022, 03:31 PM
wonkipop   [quote name='Van B' post='3024442' date='Aug 23 ...   Aug 25 2022, 03:36 PM
StarBear   [quote name='StarBear' post='3024803' date='Aug 2...   Aug 25 2022, 03:50 PM
wonkipop   [quote name='StarBear' post='3024803' date='Aug ...   Aug 25 2022, 03:56 PM
Big Len   [quote name='StarBear' post='3024803' date='Aug ...   Aug 25 2022, 04:01 PM
StarBear   My only gripe about the 74 1.8 is that emissions ...   Aug 25 2022, 03:28 PM
wonkipop   thanks @Big Len :beer2: apologies [b]@[url=ht...   Aug 25 2022, 04:10 PM
Van B   Wonki, this is mine. Glued down and doesn’t com...   Aug 25 2022, 05:06 PM
Van B   @davep sorry for the delay, this is for your inte...   Aug 25 2022, 05:10 PM
wonkipop   thanks @Van B (ah the interlock, the horror, th...   Aug 25 2022, 05:27 PM
davep   That is a great photo set. The painted male spade ...   Aug 26 2022, 05:24 PM
StarBear   Van; does this help? From George’s Tech Tips 700...   Aug 27 2022, 12:36 PM
Van B   It ain’t listed there either @StarBear , but if...   Aug 27 2022, 06:28 PM
StarBear   It ain’t listed there either [b]@[url=http://w...   Aug 27 2022, 08:00 PM
Van B   Almost everything new you can buy will be 8.8 at l...   Aug 28 2022, 07:54 AM
Van B   Been spending a lot of time LARPing as a type 4 en...   Sep 2 2022, 06:12 PM
bkrantz   Been spending a lot of time LARPing as a type 4 e...   Sep 2 2022, 07:45 PM
StarBear   Yuck. Keep up the great work, Van!   Sep 2 2022, 06:52 PM
Van B   So true!   Sep 2 2022, 08:22 PM
type2man   How come you took it apart. It only had 53k.   Sep 2 2022, 08:59 PM
wonkipop   How come you took it apart. It only had 53k. ...   Sep 2 2022, 09:40 PM
Van B   [quote name='type2man' post='3026816' date='Sep 2...   Sep 3 2022, 09:25 AM
wonkipop   [quote name='type2man' post='3026816' date='Sep ...   Sep 3 2022, 05:29 PM
Van B   Basically because the car was 100% original in all...   Sep 2 2022, 09:21 PM
Van B   @Mikey914 Mark, in the pic I posted yesterday, t...   Sep 3 2022, 09:23 AM
Van B   Man… such an absolutely tedious task. But I kno...   Sep 4 2022, 05:40 PM
wonkipop   It’s important to me the car should keep its s...   Sep 4 2022, 06:11 PM
Van B   I think a lot of it has to do with the car itself....   Sep 4 2022, 07:07 PM
wonkipop   I think a lot of it has to do with the car itself...   Sep 5 2022, 03:27 AM
Van B   So, last weekend I bought an abrasive blaster tank...   Sep 17 2022, 04:46 PM
wonkipop   So, last weekend I bought an abrasive blaster tan...   Sep 17 2022, 05:50 PM
Van B   I’ll be back on task soon, I just thou you all m...   Sep 17 2022, 04:47 PM
TJB/914   I’ll be back on task soon, I just thou you all ...   Oct 13 2022, 06:06 AM
Cairo94507   I like that table and chairs; good find and buy. ...   Sep 17 2022, 05:49 PM
Van B   Thanks guys. I really like the idea that this thi...   Sep 17 2022, 06:25 PM
StarBear   Score!!   Sep 17 2022, 07:02 PM
Van B   I did some sand blasting in the engine bay yesterd...   Sep 24 2022, 07:41 PM
Van B   Did some fine grit soda blasting on the longs… d...   Sep 25 2022, 10:53 PM
Van B   As for the engine bay, I’ve finally reached the ...   Sep 25 2022, 11:03 PM
wonkipop   some people are lucky. blessed with it. you are o...   Sep 26 2022, 04:57 AM
Van B   Getting a little behind on updates here. I know t...   Oct 12 2022, 11:15 PM
Van B   After the firewall, a lightbulb came on that resul...   Oct 12 2022, 11:18 PM
Van B   Thanks Tom lol… it’s a tall order to ever get ...   Oct 15 2022, 09:06 PM
Van B   Been working on the trunk hinges: It was super di...   Oct 15 2022, 09:52 PM
Van B   Then I decided it would be wise to test out this f...   Oct 15 2022, 09:53 PM
Van B   New hinge assembly time: Decided to radius the ou...   Oct 15 2022, 09:58 PM
Van B   And this is where I ended up tonight: I got the h...   Oct 15 2022, 10:01 PM
Van B   Glad I thought of the nut as an alignment tool, de...   Oct 16 2022, 03:43 PM
Van B   No doubt those birdshit welds put a lot of trash i...   Oct 16 2022, 03:49 PM
wonkipop   copper weld through primer is good stuff. used a l...   Oct 16 2022, 05:20 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 07:23 PM
