Hot start problem, Checking opinions before I buy a new battery |
Highland |
Aug 11 2022, 03:15 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
My car starts easily when cold, but hot it has been a struggle. I put a variable resistor on the CHT as an experiment without success. Engine's not even catching.
Plugs look good, 123 distributor, blue coil, valves adjusted, runs fantastic once started. I am using a 2 year old motorcycle AGM battery(which has been working prior to 123 distributor install). Open voltage measures at 12.6V. I stuck a lead on the coil while cranking and voltage drops to around 10V and will bounce down to 0 occasionally if I crank for more than a few seconds. With ignition only the coil is at about 12.3V. The blue coil is an NOS coil that I had. It's probably over 30 years old but resistance is good when cold. I did not think to measure the resistance hot, but would it make a difference? Does the insulation breakdown over time even if resistance is good? Thinking my little battery doesn't have enough power to crank and fire the coil. Any opinions? Cranking is strong. |
76-914 |
Aug 17 2022, 06:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Does your ECU have the idle adj knob? If so, lean it out there. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 04:41 AM |
