Hot start problem, Checking opinions before I buy a new battery |
Highland |
Aug 11 2022, 03:15 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
My car starts easily when cold, but hot it has been a struggle. I put a variable resistor on the CHT as an experiment without success. Engine's not even catching.
Plugs look good, 123 distributor, blue coil, valves adjusted, runs fantastic once started. I am using a 2 year old motorcycle AGM battery(which has been working prior to 123 distributor install). Open voltage measures at 12.6V. I stuck a lead on the coil while cranking and voltage drops to around 10V and will bounce down to 0 occasionally if I crank for more than a few seconds. With ignition only the coil is at about 12.3V. The blue coil is an NOS coil that I had. It's probably over 30 years old but resistance is good when cold. I did not think to measure the resistance hot, but would it make a difference? Does the insulation breakdown over time even if resistance is good? Thinking my little battery doesn't have enough power to crank and fire the coil. Any opinions? Cranking is strong. |
emerygt350 |
Aug 17 2022, 06:47 PM
Advanced Member Group: Members Posts: 2,138 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
If your cold start is bypassed I wonder if something else is mucked with or broken to get you a good cold start which then bites you in the rear on a hot start.
Are you sure everything is kosher on your fuel injection system? Above you mention a 123dizzy. Is that still the case? Is this a 2.0 or 1.7? What year is it? |
Lo-Fi Version | Time is now: 6th June 2024 - 11:30 PM |
