| Van B |
Aug 16 2022, 05:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
Evening 914 World!
I’ve been gathering parts over the past few months and have finally reached critical mass. So, let the project thread begin! After working on the FI through the winter, I’m satisfied that the engine remains in good health with it’s original 53k miles. However, the rubber and plastic holding everything together is a different story. Which brings me to the scope and objective of this project. In short, I am looking for what I will call, “Improved Original”. What the phrase means to me is that I want to maintain the character and feel of the original car, but still take advantage of any and all modern improvements that will either, improve reliability, safety, operability, or any combination there of. This will include a suspension and chassis rebuild, power train reseal and refinishing, brake system rebuild, and fuel system overhaul. When I’m done, I want to have a car that drives like it’s nearly new, but doesn’t look over restored. Because the car is a survivor, I think it’s important to keep the stories and history of the car intact. Finally, I’d like to post my thanks to the community and vendors that make it possible to enjoy this hobby. Stay tuned! Van Attached thumbnail(s) |
| wonkipop |
Aug 17 2022, 05:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
@StarBear - you undo the 2 smaller M8 bolts on each mount as well and slide the whole thing out towards front of car. you loosen the centre bolt only enough allow it to slide through the forked mount and get it out.
then you can take the mount out and take it apart. take a photo. get all the washers and everything back in correctly in sequence with the new mount. install reverse order or removal. thats why you need the torque setting of that big central bolt. normally when you drop engine and trans as unit you just undo the 2 M8 bolts either side and leave the central bolt alone and leave the mounts on the gearbox. the nuts would be down on yours (as they are on mine) because whoever did it wanted to torque them up with a torque wrench from the bottom. (i realise there are contrary views on that - would be interested to know how the install was done with the nuts up (IMG:style_emoticons/default/beerchug.gif) ). |
| StarBear |
Aug 17 2022, 07:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,259 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
@StarBear - you undo the 2 smaller M8 bolts on each mount as well and slide the whole thing out towards front of car. you loosen the centre bolt only enough allow it to slide through the forked mount and get it out. then you can take the mount out and take it apart. take a photo. get all the washers and everything back in correctly in sequence with the new mount. install reverse order or removal. thats why you need the torque setting of that big central bolt. normally when you drop engine and trans as unit you just undo the 2 M8 bolts either side and leave the central bolt alone and leave the mounts on the gearbox. the nuts would be down on yours (as they are on mine) because whoever did it wanted to torque them up with a torque wrench from the bottom. (i realise there are contrary views on that - would be interested to know how the install was done with the nuts up (IMG:style_emoticons/default/beerchug.gif) ). Ohhhhhh. I can see clearly now! SLIDE forward. Will await the torque setting. Still learning, thanks to The Wise Ones. (IMG:style_emoticons/default/beerchug.gif) |
Van B Bringing it back: Aug 16 2022, 05:51 PM
Van B Day 1: removed the engine :beer2: Aug 16 2022, 05:53 PM
StarBear :popcorn: Anxious to follow your exploits, Van, p... Aug 16 2022, 05:57 PM
emerygt350 Good luck van! Everytime I dig around in mine... Aug 16 2022, 06:14 PM
Van B Thanks guys! @StarBear most of those choice... Aug 16 2022, 06:36 PM
StarBear
Thanks guys! [b]@[url=http://www.914world.c... Aug 16 2022, 06:42 PM
Van B These guys: https://www.fcpeuro.com/products/porsc... Aug 16 2022, 07:15 PM
StarBear
These guys: https://www.fcpeuro.com/products/pors... Aug 16 2022, 08:02 PM
Van B
[quote name='Van B' post='3022989' date='Aug 16 2... Aug 16 2022, 08:10 PM
StarBear
[quote name='Van B' post='3022989' date='Aug 16 ... Aug 17 2022, 10:42 AM
StarBear
[quote name='Van B' post='3023004' date='Aug 16 2... Aug 17 2022, 02:22 PM
Van B
[quote name='Van B' post='3023004' date='Aug 16 ... Aug 17 2022, 02:45 PM
StarBear
[quote name='StarBear' post='3023191' date='Aug 1... Aug 17 2022, 03:45 PM
wonkipop
[quote name='Van B' post='3023004' date='Aug 16 ... Aug 17 2022, 05:22 PM
wonkipop
Van; Rats. Looked under there and the center bolt... Aug 17 2022, 10:16 PM
wonkipop you and your car will enjoy those bilsteins i see ... Aug 16 2022, 07:33 PM
Van B
you and your car will enjoy those bilsteins i see... Aug 16 2022, 08:14 PM
bbrock I will watching this for sure! :popcorn: Th... Aug 16 2022, 07:43 PM
Van B @[url=http://www.914world.com/bbs2/index.php?showu... Aug 16 2022, 08:24 PM
bbrock
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 16 2022, 08:51 PM
Van B You only need to loosen it enough to slip the moun... Aug 17 2022, 04:34 PM
StarBear
You only need to loosen it enough to slip the mou... Aug 17 2022, 05:30 PM
wonkipop @Van B
are you going to install sway bars? Aug 17 2022, 05:30 PM
Van B
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 17 2022, 05:53 PM
Van B No worries @StarBear . You’re over thinking it.... Aug 17 2022, 05:59 PM
wonkipop this might also give you pause to think @StarBear... Aug 17 2022, 11:55 PM
StarBear If it’s good enough for @wonkipop , it’s good... Aug 18 2022, 05:42 AM
StarBear Van; would these be the torques you mentioned? #2 ... Aug 19 2022, 03:13 PM
Van B Steve, for the life of me, I can’t find the M12 ... Aug 19 2022, 05:09 PM
StarBear :cheer: :Qarl: :beer2: Onward! Thanks and b... Aug 19 2022, 05:35 PM
Van B So the theme of today is: Better lucky than good a... Aug 20 2022, 07:03 PM
Van B Another lesson for folks: Don’t use spray adhesi... Aug 20 2022, 07:09 PM
wonkipop
Another lesson for folks: Don’t use spray adhes... Aug 20 2022, 07:20 PM
wonkipop car gets better the deeper you go.
:beer2: Aug 20 2022, 07:10 PM
Van B It’s original zeibart coating and it was sprayed... Aug 20 2022, 07:28 PM
wonkipop
It’s original zeibart coating and it was spraye... Aug 20 2022, 07:42 PM
Van B Electrolysis for the win. Only had a couple hours... Aug 21 2022, 06:37 PM
wonkipop still a lucky man.
have you taken the sill roc... Aug 21 2022, 11:51 PM
Van B Haven’t taken the rockers off yet, but I’m rea... Aug 22 2022, 03:13 PM
Van B Bottom line, for the engine bay, I have a few pinh... Aug 22 2022, 03:15 PM
wonkipop there is one place left after you look behind the ... Aug 23 2022, 03:03 AM
Van B You mean that little box section reinforcement dow... Aug 23 2022, 11:18 AM
wonkipop
You mean that little box section reinforcement do... Aug 23 2022, 04:38 PM
wonkipop quick question for you @Van B while i think of i... Aug 23 2022, 05:43 PM
Van B Black on my car. Aug 23 2022, 06:05 PM
wonkipop
Black on my car.
thanks mate. :beer2:
the c... Aug 23 2022, 06:10 PM
Van B My only gripe about the 74 1.8 is that emissions f... Aug 23 2022, 06:45 PM
wonkipop
My only gripe about the 74 1.8 is that emissions ... Aug 25 2022, 02:28 PM
StarBear
[quote name='Van B' post='3024442' date='Aug 23 2... Aug 25 2022, 03:31 PM
wonkipop
[quote name='Van B' post='3024442' date='Aug 23 ... Aug 25 2022, 03:36 PM
StarBear
[quote name='StarBear' post='3024803' date='Aug 2... Aug 25 2022, 03:50 PM
wonkipop
[quote name='StarBear' post='3024803' date='Aug ... Aug 25 2022, 03:56 PM
Big Len
[quote name='StarBear' post='3024803' date='Aug ... Aug 25 2022, 04:01 PM
StarBear
My only gripe about the 74 1.8 is that emissions ... Aug 25 2022, 03:28 PM
wonkipop thanks @Big Len :beer2:
apologies [b]@[url=ht... Aug 25 2022, 04:10 PM
Van B Wonki, this is mine. Glued down and doesn’t com... Aug 25 2022, 05:06 PM
Van B @davep sorry for the delay, this is for your inte... Aug 25 2022, 05:10 PM
wonkipop thanks @Van B
(ah the interlock, the horror, th... Aug 25 2022, 05:27 PM
davep That is a great photo set. The painted male spade ... Aug 26 2022, 05:24 PM
StarBear Van; does this help? From George’s Tech Tips 700... Aug 27 2022, 12:36 PM
Van B It ain’t listed there either @StarBear , but if... Aug 27 2022, 06:28 PM
StarBear
It ain’t listed there either [b]@[url=http://w... Aug 27 2022, 08:00 PM
Van B Almost everything new you can buy will be 8.8 at l... Aug 28 2022, 07:54 AM
Van B Been spending a lot of time LARPing as a type 4 en... Sep 2 2022, 06:12 PM
bkrantz
Been spending a lot of time LARPing as a type 4 e... Sep 2 2022, 07:45 PM
StarBear Yuck. Keep up the great work, Van! Sep 2 2022, 06:52 PM
Van B So true! Sep 2 2022, 08:22 PM
type2man How come you took it apart. It only had 53k. Sep 2 2022, 08:59 PM
wonkipop
... Sep 2 2022, 09:40 PM
Van B
[quote name='type2man' post='3026816' date='Sep 2... Sep 3 2022, 09:25 AM
wonkipop
[quote name='type2man' post='3026816' date='Sep ... Sep 3 2022, 05:29 PM
Van B Basically because the car was 100% original in all... Sep 2 2022, 09:21 PM
Van B @Mikey914
Mark, in the pic I posted yesterday, t... Sep 3 2022, 09:23 AM
Van B Man… such an absolutely tedious task. But I kno... Sep 4 2022, 05:40 PM
wonkipop
It’s important to me the car should keep its s... Sep 4 2022, 06:11 PM
Van B I think a lot of it has to do with the car itself.... Sep 4 2022, 07:07 PM
wonkipop
I think a lot of it has to do with the car itself... Sep 5 2022, 03:27 AM
Van B So, last weekend I bought an abrasive blaster tank... Sep 17 2022, 04:46 PM
wonkipop
So, last weekend I bought an abrasive blaster tan... Sep 17 2022, 05:50 PM
Van B I’ll be back on task soon, I just thou you all m... Sep 17 2022, 04:47 PM
TJB/914
I’ll be back on task soon, I just thou you all ... Oct 13 2022, 06:06 AM
Cairo94507 I like that table and chairs; good find and buy. ... Sep 17 2022, 05:49 PM
Van B Thanks guys. I really like the idea that this thi... Sep 17 2022, 06:25 PM
StarBear Score!! Sep 17 2022, 07:02 PM
Van B I did some sand blasting in the engine bay yesterd... Sep 24 2022, 07:41 PM
Van B Did some fine grit soda blasting on the longs… d... Sep 25 2022, 10:53 PM
Van B As for the engine bay, I’ve finally reached the ... Sep 25 2022, 11:03 PM
wonkipop some people are lucky.
blessed with it.
you are o... Sep 26 2022, 04:57 AM
Van B Getting a little behind on updates here. I know t... Oct 12 2022, 11:15 PM
Van B After the firewall, a lightbulb came on that resul... Oct 12 2022, 11:18 PM
Van B Thanks Tom lol… it’s a tall order to ever get ... Oct 15 2022, 09:06 PM
Van B Been working on the trunk hinges:
It was super di... Oct 15 2022, 09:52 PM
Van B Then I decided it would be wise to test out this f... Oct 15 2022, 09:53 PM
Van B New hinge assembly time:
Decided to radius the ou... Oct 15 2022, 09:58 PM
Van B And this is where I ended up tonight:
I got the h... Oct 15 2022, 10:01 PM
Van B Glad I thought of the nut as an alignment tool, de... Oct 16 2022, 03:43 PM
Van B No doubt those birdshit welds put a lot of trash i... Oct 16 2022, 03:49 PM
wonkipop copper weld through primer is good stuff.
used a l... Oct 16 2022, 05:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:28 PM |
