Differential Spacers, I forgot which side they go on |
pek771 |
Aug 17 2022, 03:25 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
I am putting in a Quaife TBD. I pulled the shims/spacers off the old differential. and did not note which went where. One is around .010" thicker than the other. Was this how they set up ring and pinions back in the old days? Is there a spec for this somewhere?
mgphoto |
Aug 18 2022, 10:59 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
This is the tool to set pinion depth, the procedure is in the factory manual but also read the Sportomatic section as it is much more detailed in the procedure description although the numbers are different.
After the pinion depth is set the backlash needs to be set. Spacers under the carrier bearings need to be replaced as necessary to position the ring gear in the correct position. The difficult part is not destroying the bearing cages pulling them off and replacing the spacers. The backlash is measured with this type of rig. The results can be very satisfying. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:41 AM |
